moving a widget within a window
  • moving a widget within a window
    Hello to everybody,
    is there anyone who knows if it is possible to move a widget within a window?
    I am developing an application where there is an image widget inside the window
    and I would like to move the image object around the window area.
    Since I do not know how to move the widget I am trying to use the GUI_DrawBitmap
    function as a workaround but the image is not visible, it seems it is rendered 'under'
    the window as if GUI_* functions were not able to draw over the currently visible window.
    Thanks a lot to whom that can provide some hints.
    Ezio
  • Hello Ezio,
    Have you tried using the function WM_SetWindowPos()?
    Please note that drawing functions should be called from within a callback function as a reaction to the WM_PAINT event. Details can be found in the chapter "The Window Manager (WM)" in the emWin user manual.
    Adrian
