J-Link v9 and MPLABX
    J-Link support has been added in MPLAB X V2.15 (which is not the final version, since PIC32MZ support is also going to be added etc.).
    Please note that GDBServer is *not* necessary to use J-Link in MPLAB X. MPLAB X supports J-Link natively.
    GDBServer allows using J-Link also with other IDEs than MPLAB X, which are based on GDB (e.g. emIDE: emide.org/).
    Anyhow, we will also add MPLAB X to the list of supported IDEs and will also have a small dedicated MPLAB X page, as available for most other IDEs.
  • Related to this, I tried using a J-link v8 EDU (latest firmware) with MPLAB X 2.15, but only got an error message about the combination of a MIPS CPU and JTAG not being supported on this hardware. Are there any extra hardware limitations over those mentioned on the PIC32 support info page? The CPU I was trying to connect to was a PIC32MX795F512L, using 4-wire JTAG.
    I was able to use J-Link v9, software 4.86b, with MPLABX 2.15 and PIC32MX795F512L. However:
    - Download speed is very low compare to ICD3
    - While debugging, the MCU runs at very low speed. Reset and let the PIC32 runs alone then everything is normal.
    - Hit "halt" I got this mesasge "Unable to halt the target device.JLINK_Halt command failed with value -142"
    - Is it possible to have live update watch like in IAR or Keil MDK in the future?
    We are currently working on a new version of the DLL in which the download speed has been improved (see PIC32 info page which already shows the new values)
    J-Link is more than 2 times faster than the ICD3, on the PIC32MX...
    Just to be sure: You are debugging via the 14-pin header, correct?
    Since the RJ11 connector is for 2-wire JTAG (different pins) which is not supported by the PIC32MX795.
    See PIC32 info page for more information.
    Maybe, but it will not be the same like on for example Cortex-M because the PIC32 does not support reading/writing memory without halting the CPU.
    Alright, unfortunately, 2-wire ICSP is not usable for debugging and the MX795 does not support 2-wire JTAG debugging.
    What ICD3 does: Downloading a special handler into flash which communicates via a proprietary protocol,
    causing the target application to stop immediately in case no debugger is connected, making it impossible to perform post-mortem debugging of release versions.
