J-link SAM4L-EK error "Failed to launch program. Error: Failed to write DP register 0x2"
  • J-link SAM4L-EK error "Failed to launch program. Error: Failed to write DP register 0x2"
    Hi, Help!
    I am working with Atmel Studio, the SAM4L-EK and Jlink
    The system worked briefly using one of the sample examples to make sure the system worked but now I always get the same error
    Failed to Launch program
    Studio can communicate with the SAM4, the SAM4L can be erased and signature bytes read, etc....
    The Jlink device seems to be working
    There aren't any errors reporting in building the solution
    Sorry but I am stumped, can somebody help a brother out?
    Rather than include tons of messages from Studio, I pared it down to this,
    Lots of stuff before this…
    Finished
    building: ../src/spi_example.c
    Building
    target: SPI_EXAMPLE1.elf
    Invoking:
    ARM/GNU Linker : 4.8.3
    "D:\Program
    Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.8.1426\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe"
    -o SPI_EXAMPLE1.elf
    src/ASF/common/services/clock/sam4l/dfll.o
    src/ASF/common/services/clock/sam4l/osc.o
    src/ASF/common/services/clock/sam4l/pll.o src/ASF/common/services/clock/sam4l/sysclk.o
    src/ASF/common/services/delay/sam/cycle_counter.o
    src/ASF/common/services/serial/usart_serial.o
    src/ASF/common/utils/interrupt/interrupt_sam_nvic.o
    src/ASF/common/utils/stdio/read.o src/ASF/common/utils/stdio/write.o
    src/ASF/sam/boards/sam4l_ek/board_monitor.o src/ASF/sam/boards/sam4l_ek/init.o
    src/ASF/sam/drivers/bpm/bpm.o src/ASF/sam/drivers/flashcalw/flashcalw.o
    src/ASF/sam/drivers/spi/spi.o src/ASF/sam/drivers/usart/usart.o
    src/ASF/sam/drivers/wdt/wdt_sam4l.o
    src/ASF/sam/utils/cmsis/sam4l/source/templates/exceptions.o src/ASF/sam/utils/cmsis/sam4l/source/templates/gcc/startup_sam4l.o
    src/ASF/sam/utils/cmsis/sam4l/source/templates/system_sam4l.o
    src/ASF/sam/utils/syscalls/gcc/syscalls.o src/spi_example.o -mthumb -Wl,-Map="SPI_EXAMPLE1.map"
    -Wl,--start-group -larm_cortexM4l_math -lm
    -Wl,--end-group -L"../cmsis/linkerScripts"
    -L"../src/ASF/thirdparty/CMSIS/Lib/GCC" -Wl,--gc-sections -mcpu=cortex-m4
    -Wl,--entry=Reset_Handler -Wl,--cref -mthumb
    -T../src/ASF/sam/utils/linker_scripts/sam4l/sam4l4/gcc/flash.ld
    Finished
    building target: SPI_EXAMPLE1.elf
    "D:\Program
    GCC\Native\4.8.1426\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe" -O
    binary "SPI_EXAMPLE1.elf" "SPI_EXAMPLE1.bin"
    "D:\Program
    Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.8.1426\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe"
    -O ihex -R .eeprom -R .fuse -R .lock -R .signature "SPI_EXAMPLE1.elf"
    "SPI_EXAMPLE1.hex"
    "D:\Program
    GCC\Native\4.8.1426\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe" -j
    .eeprom --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0
    --no-change-warnings -O binary "SPI_EXAMPLE1.elf"
    "SPI_EXAMPLE1.eep" || exit 0
    "D:\Program
    Files (x86)\Atmel\Atmel Toolchain\ARM GCC\Native\4.8.1426\arm-gnu-toolchain\bin\arm-none-eabi-objdump.exe"
    -h -S "SPI_EXAMPLE1.elf" > "SPI_EXAMPLE1.lss"
    "D:\Program
    srec -R .eeprom -R .fuse -R .lock -R .signature
    "SPI_EXAMPLE1.elf" "SPI_EXAMPLE1.srec"
    "D:\Program
    GCC\Native\4.8.1426\arm-gnu-toolchain\bin\arm-none-eabi-size.exe"
    "SPI_EXAMPLE1.elf"
    text data bss dec hex filename
    26628 0 4392 31020 792c SPI_EXAMPLE1.elf
    Done
    executing task "RunCompilerTask".
    Using
    "RunOutputFileVerifyTask" task from assembly "D:\Program Files
    (x86)\Atmel\Atmel Studio 6.2\Extensions\Application\AvrGCC.dll".
    Task
    Program
    Memory Usage : 26628 bytes 10.2 % Full
    Data
    Memory Usage : 4392 bytes 12.6 % Full
    Done
    executing task "RunOutputFileVerifyTask".
    Done building target
    "CoreBuild" in project "SPI_EXAMPLE1.cproj".
    Target "PostBuildEvent"
    skipped, due to false condition; ('$(PostBuildEvent)' != '') was evaluated as
    Target "Build" in file
    "D:\Program Files (x86)\Atmel\Atmel Studio 6.2\Vs\Avr.common.targets"
    from project "C:\Users\tambrose.LPA.000\Documents\Atmel
    Studio\6.2\SPI_EXAMPLE1\SPI_EXAMPLE1\SPI_EXAMPLE1.cproj" (entry point):
    "Build" in project "SPI_EXAMPLE1.cproj".
    Done building project
    Build succeeded.
    ========== Build: 1 succeeded or
    up-to-date, 0 failed, 0 skipped ==========
  • Kind of sounds like the problem I was having last week with my sam3u-ek and sam-ice debugger where my code was disabling the debug port and thus having connectivity error. You probably have to erase the memory chip so the debug port is enabled again, but what output are you getting from Jlink.exe? Can anyone confirm with me?
    I agree to euphoricnoise. Would be interesting to see what the output of J-Link Commander (JLink.exe) is.
  • Thanks for the replys
    The problem has been "fixed"
    I set up a new installation of Atmel Studio on a machine that never had any tools installed and ran the project all over again. The results were exactly the same. Different machine, same result. problem tracks hardware.
    A co-worker of mine walked by and offered to try it on his machine with code he had written for another project, the project loaded and executed
    When I went back to my desk and tried the original project again, it worked and has been working ever since
    Puzzling
    Thanks again
    Good to hear that it is working now.
    Anyhow, does not really sound good that it is working "out of the sudden"...
    Would be good to understand where the problem came from, to make sure that it is not hardware related and does not show up again.
    - Alex
