New STM32F4 Internal Flash programming problem
  • New STM32F4 Internal Flash programming problem
    We are currently working with a new STM32F4 chip with the following internal flash and Ram address:
    iROM - Starting address: 0x00000000, Size = 1M bytes
    iRAM - Starting address: 0x20000000, Size = 128K bytes
    So far we have not been able to transfer program into the internal flash of this new STM32F4 device. We have tested on IAR EWM, KEIL uVison 5 as well as Coocox IDE and none of them work. We are able to debug the program when the program code is loaded into RAM but not when we select the program to be stored into the embedded flash. When we attempted to debug program in flash in KEIL uVison 5 the log windows said "No algorithm for address xxxx".
    We checked all the existing STM32F4 devices and their iROM always start at 0x80000000. This new device seems to be the only STM32F4 where the iROM starts from 0x00000000. Does J-Link need a special algorithm to handle flash programming of a STM32F4 device that is starting at address 0x00000000? If so how can we obtain the algorithm?
    Thank you in advance for any help.
    P/S: The log file for KEIL uVision 5 shows the following error:The log windows show the following errors:
    Load "D:\\STMT\\Projects\\PLC2\\MDK-ARM\\PLC2\\PLC2.axf"
    * JLink Info: Device "UNSPECIFIED" selected (0 KB flash, 0 KB
    RAM).
    Set JLink Project File to
    "D:\STM\Projects\PLC2\MDK-ARM\JLinkSettings.ini"
    RAM).
    JLink info:
    DLL: V4.84f, compiled May 9 2014 20:05:42
    Firmware: J-Link OB-STM32F103 V1 compiled Feb 5 2014 13:48:52
    Hardware: V1.00
    S/N : 660000034
    * JLink Info: TotalIRLen = 10, IRPrint = 0x0011
    * JLink Info: Found Cortex-M4 r0p1, Little endian.
    * JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
    * JLink Info: TPIU fitted.
    * JLink Info: ETM fitted.
    ROMTableAddr = 0xE00FF003
    Target info:
    Device: ARMCM4
    VTarget = 3.300V
    State of Pins:
    TCK: 1, TDI: 0, TDO: 1, TMS: 0, TRES: 1, TRST: 1
    Hardware-Breakpoints: 6
    Software-Breakpoints: 8192
    Watchpoints: 4
    JTAG speed: 2000 kHz
    No Algorithm found for: 00000000H -
    00004643H
    Erase skipped!
    Error: Flash Download failed - "Cortex-M4"
    The post was edited 1 time, last by trilogi ().
    In general, the project must be modified in order to use the SEGGER flashloader.
    The following pages describe how to do so:
    • http://segger.com/IDE_Integration_Keil.html#usingflashloader
    • http://segger.com/IDE_Integration_IAR.html#enabling_flashloader
    • http://segger.com/IDE_Integration_Coocox.html
    We are not aware of such a device. We had a quick look on the ST homepage, but we still can not find it there.
    What is the exact name of the device? Can you provide us with any datasheets regarding this device?
    Erik
