Implement at ssd1289 and stm32f103
  • Implement at ssd1289 and stm32f103
    Hi
    For some project for school i like to run your bib.
    I find information about my LCD driver ( ssd1289 integratet at 66702 TFT driver).
    Soo find driver at china forum
    GUIConf.c /h
    GUI_X.c /h
    LCD_X_16BitIF_STM32.c /h
    LCDConf.c /h
    GUIDRV_CompactColor_16.c /h
    everything is set
    (LCD_Conf.c)
    #define VXSIZE_PHYS 240
    #define VYSIZE_PHYS 320
    #define COLOR_CONVERSION GUICC_M565
    #define DISPLAY_DRIVER GUIDRV_COMPACT_COLOR_16
    #define NUM_BUFFERS 1
    #define NUM_VSCREENS 1
    even register address for my memory (FSMC Bank1 NORSRAM1)
    (LCD_X_16BitIF_STM32.c)
    #define LCD_BASE (0x60000000UL | 0x00000000UL)
    #define LCD_REG16 (*((volatile unsigned short *)(LCD_BASE )))
    #define LCD_DAT16 (*((volatile unsigned short *)(LCD_BASE |0x00020000UL)))
    only change class
    frome GUI_context. to GUI_pcontext->
    But still i have a problem.
    1. ..\emWin\Config\GUIDRV_CompactColor_16.c(302): warning: #47-D: incompatible redefinition of macro "LCD_WRITEM_A0" (declared at line 60 of "..\emWin\Config\LCDConf_CompactColor_16.h")..\emWin\Config\GUIDRV_CompactColor_16.c(306): warning: #47-D: incompatible redefinition of macro "LCD_READM_A1" (declared at line 61 of "..\emWin\Config\LCDConf_CompactColor_16.h")..\emWin\Config\GUIDRV_CompactColor_16.c(925): warning: #223-D: function "LCD_WRITEM_A1_0" declared implicitly..\emWin\Config\GUIDRV_CompactColor_16.c(939): warning: #223-D: function "LCD_WRITEM_A0_0" declared implicitly..\emWin\Config\GUIDRV_CompactColor_16.c(1475): warning: #223-D: function "LCD_WRITEM_A1_0" declared implicitly..\emWin\Config\GUIDRV_CompactColor_16.c(1516): warning: #223-D: function "LCD_WRITEM_A1_0" declared implicitly..\emWin\Config\GUIDRV_CompactColor_16.c(1574): warning: #223-D: function "LCD_WRITEM_A1_0" declared implicitly..\emWin\Config\GUIDRV_CompactColor_16.c(2709): warning: #223-D: function "LCD_WRITEM_A1_0" declared implicitly..\emWin\Config\GUIDRV_CompactColor_16.c(2786): warning: #144-D: a value of type "void (*)(int, int, int, int)" cannot be used to initialize an entity of type "int (*)(int, int, int, int)"..\emWin\Config\GUIDRV_CompactColor_16.c(3118): error: #147: declaration is incompatible with "void (*LCD_L0_CompactColor_16_GetDevFunc(int))(void)" (declared at line 100 of "..\emWin\Include\GUIDRV_Generic.h")Target not created
    Before I find almost 40 examples/ settings use your driver, But run only one time and it was soo slow and some demos was spiked or freeze
    my unwork project
    https://drive.google.com/file/d/0B-tweXloR_jHeDJlNWZpdkp6VjQ/edit?usp=sharing
    And my almost work spagetti(rename register and initialization procedure LCD_SPFD5420)
    https://drive.google.com/file/d/0B-tweXloR_jHQl9CSjJLYzg0V0k/edit?usp=sharing
    If some wan have to time please look at it
    I wrote it again and now it work :D
    The post was edited 3 times, last by tomasz1987 ().
