[SOLVED] J-Flash - Merge intel hex or motorola srec
  • [SOLVED] J-Flash - Merge intel hex or motorola srec
    Id like to merge two intel hex or Motorola srec files (built with IAR EWARM)
    What I do:
    - File - Open Data file (open file #1)
    - File - Merge Data file (open file #2)
    The log says:
    Opening data file [C:\workspace\file1.srec] ...
    - Data file opened successfully (37572 bytes, 2 ranges, CRC = 0x0DCC4286)
    Merging data file [C:\workspace\file2.srec] ...
    - Data file merged successfully (37572 bytes, 2 ranges, CRC = 0x0DCC4286)
    But: the file shown is still the unchanged file #1.
    Also when I safe the data file just the file #1 is saved.
    what am I doing wrong?
    Can you please attached both files, so we can give it a quick try here?
    We are not aware of any problems with the merging functionality in J-Flash
    - Alex
    the problem here is that both files intersects in different sections.
    For example:
    File1:
    0x13C00 - 0x16FFF
    File2:
    0x14400 - 0x1A890
    This is something which was not supported by J-Flash yet.
    We already extended J-Flash, so that it does now also support merging of sections which exists in both files.
    The user will be asked when merging intersects files before J-Flash proceeds. In cases like this, the overlapping areas
    will be replaced by the one of the selected file (selected via pop-up dialog).
    We plan to have a new version, in which this feature will be available maybe today or next week.
    Erik
    The new beta version (V4.85e) which comes with this feature, is available for download:
    segger.com/jlink-software-beta-version.html
    Short feedback would be appreciated.
    - Alex
