I'm using GDB/GDB Server on OSX. When attempting to flash to an Analog Devices Cortex-M3 the verification step fails. GDB server output and .gdbinit included below.
Kenny
.gdbinit
GDB Server Output
Kenny
.gdbinit
GDB Server Output
- SEGGER J-Link GDB Server V4.84f Command Line Version
- JLinkARM.dll V4.84f (DLL compiled May 9 2014 20:17:59)
- -----GDB Server start settings-----
- GDBInit file: none
- GDB Server Listening port: 2331
- SWO raw output listening port: 2332
- Terminal I/O port: 2333
- Accept remote connection: yes
- Generate logfile: off
- Verify download: off
- Init regs on start: on
- Silent mode: off
- Single run mode: off
- Target connection timeout: 5 sec.
- ------J-Link related settings------
- J-Link Host interface: USB
- J-Link script: none
- J-Link settings file: none
- ------Target related settings------
- Target device: ADUCM320
- Target interface: SWD
- Target interface speed: 1000kHz
- Target endian: little
- Connecting to J-Link...
- J-Link is connected.
- Firmware: J-Link Lite-ADI Rev.1 compiled Jan 7 2013 17:58:04
- Hardware: V1.00
- S/N: 541000757
- OEM: ADI
- Checking target voltage...
- Target voltage: 3.58 V
- Listening on TCP/IP port 2331
- Connecting to target...Connected to target
- Waiting for GDB connection...Connected to 127.0.0.1
- Reading all registers
- Read 1 bytes @ address 0x00000000 (Data = 0xFF)
- Target endianess set to "little endian"
- Resetting target
- Sleep 100ms
- Selecting device: ADUCM320
- Flash download enabled
- Selecting work RAM area (0x20000000-0x2003FFFF)
- Selecting CFI flash area (0x00000000-0x00020000)
- GDB closed TCP/IP connection
- Connected to 127.0.0.1
- Resetting target
- Sleep 100ms
- Downloading 392 bytes @ address 0x00000000
- Downloading 1232 bytes @ address 0x00000188
- Downloading 8 bytes @ address 0x00000658
- Downloading 8 bytes @ address 0x00000660
- Downloading 12 bytes @ address 0x00000668
- Downloading 4 bytes @ address 0x00000674
- Downloading 1076 bytes @ address 0x00000678
- Downloading 4 bytes @ address 0x00000AAC
- ERROR: Verification failed @ address 0x00000000
- Writing register (R8 = 0x00000265)
- Reading from address 0x00000000 (Data = 0xFFFFFFFF)
