J-Link EDU doesn't work with STM32F103ZE and SW
  • J-Link EDU doesn't work with STM32F103ZE and SW
    i bought the J-Link EDU to try some small projects at home. I try to connect a µLink-ME from my job and it works well with the setting SW (SWJ) and 1 MHz. The J-Link with the same settings doesn't work. (Keil and J-Link tools)
    It showns no recognized Controller.
    What can i try?
    vokuit00
    What can i try?
    Providing some more information:
    Are you using an eval board or custom hardware?
    Which version of the Keil MDK / uVision are you using?
    Can you send us the project, so we can have a quick look at it to check if there is anything odd in the MDKJ-Link settings?
    - Alex
    i use Keil 4 on a custom board. As attachment i send you the screenshots from ulink-ME and J-Link EDU. ulink founds the device, J-Link not. Connected via the original 20 pin cable of the J-Link or hte direct connected uLink.
    Volker
    P.S. Do you have a mail address where i can send the project?
  • Hi Volker,
    E-Mail address: segger.com/support/technical-support/
    Please add a link to this thread to the e-mail.
    Strange... I do not see why the EDU should not work.
    Did you give J-Link Commander a quick try?
    It's a small command line utility that comes with the J-Link software package.
    Can you give it a quick try and post a screenshot of the output of the Commander?
    - Alex
  • Anything i should try with the commander?
    He shows that the VTarget is 0.000V. But the target has power (and ulink works).
    Volker
    The post was edited 1 time, last by Foxi ().
    It is just a guess since I do not know anything about your hardware, but this is what I assumes happens here:
    - You have manually wired the connection between J-Link & your target
    - You do not have connected pin 1 of J-Link to VCC of your target CPU
    Note:
    uLink-ME is only specified for 3.3V targets.
    J-Link is specified for 1.2 - 5V but for this, it needs to measure the target operating voltage to adapt the I/O voltage of the debug signals on the J-Link side accordingly.
    Measurement of the target voltage is done via pin 1 on the J-Link side.
    If this is not connected, J-Link assume no target is connected to J-Link, since 0V is measured.
    - Alex
  • Does this mean my assumption was correct and we can consider this as solved/closed?
    - Alex
