Widget for displaying text and icons
  • Widget for displaying text and icons
    is there a widget in emWin that is able to display text and icons within the text?
    We want to implement a context help. In the text the button icons shall be displayed
    so that the user can recognize which button the text is referring to.
    Thanks in advance,
    Stefan.
  • Hello Stefan,
    Unfortunately there is no ready-to-use widget which allows displaying text as well as images. I would recommend using the IMAGE and the TEXT widget. If you want to combine those widgets you can use a simple window as parent.
    Another idea would be using ToolTips, in case your application will be used by a mouse-based pointer input device. ToolTips do also not support images, but they are clearly recognized, since they would refer to the widget which the PID points at.
    Adrian
