what is the maximum path length in emFile?
    emFile does not explicitly limit the depth of a directory.
    There is however one API function which temporarily stores the full path to a directory: FS_CreateDir().
    It uses FS_MAX_PATH define (default: 260 bytes) to allocate the path buffer.
    Also, when emFile is compiled with FS_MULTI_HANDLE_SAFE is set to 1
    the full path to an opened file is stored internally. The maximum number of bytes in the
    path can be specified using the FS_MAX_LEN_FULL_FILE_NAME define (default: 256 bytes).
    Marius
