Regarding Multilayer & Backlight control of LCD
  • Regarding Multilayer & Backlight control of LCD
    I have a requirement of Backlight control of LCD screen.By touching the LCD screen the Backlight should on.
    But am facing a problem, on touching the sceen the backlight gets on but it also activates the widgets.
    So,i need to on only Backlight of LCD screen and not to take touch for the widgets.
    After seeing the LCD config file , came to know that we are working on single layer.
    Because of all this, i thought to use multilayer concept.
    In one layer , i can handle backlight and in other UI.
    So, if i touch the screen only the selected layer will process and not other layer.
    Is it correct to use the multilayer for the controlling the backlight , if not can you suggest the solution
    And if yes can you tell me how to configure the multilayer in a system.
    Venkat
