A Problem occured when using J-Link RDI with IAR V4.41 for STR32 Cortex M3 Core
  • A Problem occured when using J-Link RDI with IAR V4.41 for STR32 Cortex M3 Core
    I have J-Link V5.4 and using software version 3.84 with IAR EWARM V4.41
    My Target has STR32 Cortex M3 Core.
    When I tried to debug my board using J-Link with IAR V4.41, it had worked well.
    But, when I tried to use J-Link RDI with IAR V4.41 for same board, problem had occered.
    In J-Link RDI Releast note, above V3.80 of RDI supports Cortex M3(In S/W package 3.84 has RDI V3.82).
    but, when using RDI debugging in IAR, EWARM dsplayed Error Message shown below, and halted.
    "Could not write CPU register R15: Written: 0x2000004D, Read 0x2000004C"
    Below text is from tail of the RDI log file.
    T0FFC 001:418 JLINK_ReadProc (h = ARM, Addr = 0x20000E1C, 0x0004 Bytes, RDIAccess_Data32) returns RDIError_NoError (0004ms)
    T0FFC 001:422 JLINK_WriteProc(h = ARM, Addr = 0x20000E1C, 0x0004 Bytes, RDIAccess_Data32) returns RDIError_NoError (0008ms)
    T0F24 001:430 JLINK_ExecuteProc(..., h = ARM, StopOthers = TRUE)
    ***** Error: Could not write CPU register R15: Written: 0x2000004D, Read 0x2000004C
    What was wrong?
    Help!
    The post was edited 1 time, last by allan ().
  • SEGGER - Rolf wrote:
    IAR V4.41 is an older tool chain. It does not allow debugging of Cortex-M3 via RDI.
    RDI is a standard for ARM7/9 cores only; opening it for Cortex-M3 is a new project.
    So: Do not use RDI.
    In that case, what does it mean 'Version 3.80 Support for Cortex-M3' in your RDI release note?
    If above note means later version of RDI 3.80 supports Cortex-M3, which tool chain should I use?
