embOS/IP Example for Embedded Artists Board LPC1788
  • embOS/IP Example for Embedded Artists Board LPC1788
    I got a question regarding the IP code in 'IP_Config_LPC1788.c'.
    In:
    1. void IP_X_Config(void) {
    2. (...)
    3. IP_NI_LPC17xx_ConfigAddr(0x20084000, 0x20000000); // Set the address of the Ethernet MAC and Ethenrnet RAM.
    4. (...)
    5. }
    The first parameter for IP_NI_LPC17xx_ConfigAddr() is the base address of the EMAC, but the second just points to the start of AHB-RAM.
    So I guess the function uses/reserves space in AHB-RAM. But how much space? So I can spare out the area in my linker script.
    best regards,
    Arne
  • Hello Arne,
    By default the LPC17xx driver uses 4 Tx and 4 Rx buffers.
    One Tx buffer set consists of an 8 byte descriptor, 4 byte status and 1536 byte buffer for the packet itself.
    One Rx buffer set consists of an 8 byte descriptor, 8 byte status and 1536 byte buffer for the packet itself.
    This results in a total of 12400 byte that is used from the start of the configured Ethernet RAM.
    Oliver
