About GUI_SaveContext and GUI_RestoreContext
  • About GUI_SaveContext and GUI_RestoreContext
    Hi Adrian,
    I followed the example of WIDGET_Effect.c to add customized effect to EDIT, in simulation environment it works well, but after porting to embedded environment the application crashed at GUI_RestoreContext
    Is there any requirement to use the pair function GUI_SaveContext and GUI_RestoreContext ?
    Thanks.
    Zhiying Xiang
  • Hello Zhiying,
    Please note that the sample WIDGET_Effect.c does not call the function GUI_RestoreContext(). I assume you try to use the sample WIDGET_CustomEffect.c. The functions GUI_SaveContext() and GUI_RestoreContext() actually do simple copy operations which should never lead to a crash. Unfortunately I can not reproduce the problem on a target hardware.
    This sounds like you would need support to solve this problem. Please understand that I therefor have to ask you to redirect your request to your emWin vendor. If you prefer to receive direct support from SEGGER, please feel free to contact info@segger.com.
    Adrian
