Recently, started to experience difficulties to work with JLink debugger, constant failures to read memory, lost sync with MCU, absolutely impossible to debug. Thought problems with old GDB Server, upgraded to new GDB Server, which failed to work as well - Failure to verify downloaded bytes. While 4.40 Verify was ok. Attached both logs.
Current debug for application on external ram / fsmc. Dont know if that helps, IIC is DMA based and trying to debug it.
Upgraded GDB Server
SEGGER J-Link GDB Server V4.64a
JLinkARM.dll V4.64a (DLL compiled Feb 25 2013 18:26:59)
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link ARM V8 compiled Nov 14 2012 22:34:52
Hardware: V8.00
S/N: 58006752
Checking target voltage...
Listening on TCP/IP port 2331
Connecting to target...
J-Link found 2 JTAG devices, Total IRLen = 9
JTAG ID: 0x4BA00477 (Cortex-M3)
Connected to target
Reading all registers
Read 4 bytes @ address 0x00000000 (Data = 0x20018000)
JTAG speed set to 1000 kHz
Target endianess set to "little endian"
Resetting target
Flash download enabled
Flash breakpoints enabled
Writing 0x00000078 @ address 0x40023830
Writing 0x00000001 @ address 0x40023838
Writing 0xAAAA4A0A @ address 0x40020C00
Writing 0xFFFF8F0F @ address 0x40020C08
Writing 0x00CC00CC @ address 0x40020C20
Writing 0xCCCCCCCC @ address 0x40020C24
Writing 0xAAAAAAAA @ address 0x40021000
Writing 0xFFFFFFFF @ address 0x40021008
Writing 0xCCCCCCCC @ address 0x40021020
Writing 0xCCCCCCCC @ address 0x40021024
Writing 0xAA000AAA @ address 0x40021400
Writing 0xFF000FFF @ address 0x40021408
Writing 0x00CCCCCC @ address 0x40021420
Writing 0xCCCC0000 @ address 0x40021424
Writing 0x00080AAA @ address 0x40021800
Writing 0x000C0FFF @ address 0x40021808
Writing 0x00CCCCCC @ address 0x40021820
Writing 0x000000C0 @ address 0x40021824
Writing 0x00001005 @ address 0xA0000008
Writing 0x000A0888 @ address 0xA000000C
Writing 0x000A0888 @ address 0xA000010C
Reading from address 0x64000000 (Data = 0xE00321F0)
Downloading 484 bytes @ address 0x20000000 - Verify failed
Downloading 16288 bytes @ address 0x64000000 - Verify failed
Downloading 16224 bytes @ address 0x64003FA0 - Verify failed
Downloading 16288 bytes @ address 0x64007F00 - Verify failed
Downloading 16304 bytes @ address 0x6400BEA0 - Verify failed
Downloading 432 bytes @ address 0x6400FE50 - Verify failed
Downloading 16128 bytes @ address 0x64010000 - Verify failed
Downloading 16272 bytes @ address 0x64013F00 - Verify failed
Downloading 16288 bytes @ address 0x64017E90 - Verify failed
Downloading 16288 bytes @ address 0x6401BE30 - Verify failed
Downloading 560 bytes @ address 0x6401FDD0 - Verify failed
Downloading 16304 bytes @ address 0x64020000 - Verify failed
Downloading 16304 bytes @ address 0x64023FB0 - Verify failed
Downloading 16256 bytes @ address 0x64027F60 - Verify failed
Downloading 16272 bytes @ address 0x6402BEE0 - Verify failed
Downloading 400 bytes @ address 0x6402FE70 - Verify failed
Downloading 16192 bytes @ address 0x64030000 - Verify failed
Downloading 15968 bytes @ address 0x64033F40 - Verify failed
Downloading 16096 bytes @ address 0x64037DA0 - Verify failed
Downloading 16112 bytes @ address 0x6403BC80 - Verify failed
Downloading 1168 bytes @ address 0x6403FB70 - Verify failed
Downloading 2940 bytes @ address 0x64040000 - Verify failed
Downloading 11632 bytes @ address 0x64040B80 - Verify failed
Writing register (PC = 0x64000000)
Read 4 bytes @ address 0x64000000 (Data = 0xE0032100)
Read 2 bytes @ address 0x6402F1A0 (Data = 0xF04F)
WARNING: Failed to read cacheable memory @ address 0x6402F274
Read 2 bytes @ address 0x6402F274 (Data = 0xF04F)
Read 2 bytes @ address 0x6402F116 (Data = 0xF04F)
WARNING: Failed to read cacheable memory @ address 0x20007CE0
Read 4 bytes @ address 0x20007CE0 (Data = 0xE003F04F)
Old GDB Server with same application
SEGGER J-Link GDB Server V4.40
JLinkARM.dll V4.40 (DLL compiled Dec 9 2011 18:59:34)
J-Link connected
Hardware: V8.00
S/N: 58006752
Resetting target
Downloading 484 bytes @ address 0x20000000 - Verified OK
Downloading 16288 bytes @ address 0x64000000 - Verified OK
Downloading 16224 bytes @ address 0x64003FA0 - Verified OK
Downloading 16288 bytes @ address 0x64007F00 - Verified OK
Downloading 16304 bytes @ address 0x6400BEA0 - Verified OK
Downloading 432 bytes @ address 0x6400FE50 - Verified OK
Downloading 16128 bytes @ address 0x64010000 - Verified OK
Downloading 16272 bytes @ address 0x64013F00 - Verified OK
Downloading 16288 bytes @ address 0x64017E90 - Verified OK
Downloading 16288 bytes @ address 0x6401BE30 - Verified OK
Downloading 560 bytes @ address 0x6401FDD0 - Verified OK
Downloading 16304 bytes @ address 0x64020000 - Verified OK
Downloading 16304 bytes @ address 0x64023FB0 - Verified OK
Downloading 16256 bytes @ address 0x64027F60 - Verified OK
Downloading 16272 bytes @ address 0x6402BEE0 - Verified OK
Downloading 400 bytes @ address 0x6402FE70 - Verified OK
Downloading 16192 bytes @ address 0x64030000 - Verified OK
Downloading 15968 bytes @ address 0x64033F40 - Verified OK
Downloading 16096 bytes @ address 0x64037DA0 - Verified OK
Downloading 16112 bytes @ address 0x6403BC80 - Verified OK
Downloading 1168 bytes @ address 0x6403FB70 - Verified OK
Downloading 2940 bytes @ address 0x64040000 - Verified OK
Downloading 11632 bytes @ address 0x64040B80 - Verified OK
Writing register (CPSR = 0x01000000)
Read 2 bytes @ address 0x6402F274 (Data = 0xF8BD)
Read 2 bytes @ address 0x64028FD2 (Data = 0xE03B)
Read 2 bytes @ address 0x64028FFE (Data = 0x9B07)
Read 2 bytes @ address 0x6402F1A8 (Data = 0xF04F)
Writing register (SP = 0x2000A7E8)
Writing register (PC = 0x64000001)
Read 4 bytes @ address 0x20007CE0 (Data = 0x7D9CFE89)
Read 4 bytes @ address 0x4002604C (Data = 0x00000000)
Read 4 bytes @ address 0x40026064 (Data = 0x00000000)
Read 4 bytes @ address 0x40026034 (Data = 0x00000000)
Read 4 bytes @ address 0x40026074 (Data = 0x00000000)
Read 4 bytes @ address 0x40026044 (Data = 0x00000000)
Serj
Upgraded GDB Server
Hardware: V8.00
S/N: 58006752
Connected to target
Resetting target
J-Link connected
Hardware: V8.00
S/N: 58006752
Resetting target
Serj
The post was edited 1 time, last by Serj ().
