I am using the bitmap convert and convert a PNG file to a DAT file using "High color (565) bead and blue swapped"
Then i am Saving the DAT file into my FLASH and when the system is booted i am loading the DAT data from the FLASH into the RAM
When viewing the DAT file in the RAM i have checked the matching data on the file that has been converted using bitmap convert and the data in the RAM and they are matching correctly.
When i am using :
static GUI_BITMAP bmHorizenSplashScreen;
static GUI_LOGPALETTE _pPAL;
i got retunr 1 but when i am using :
GUI_CreateBitmapFromStream(&bmHorizenSplashScreen,&_pPAL, BMP_LOGO_PTR->data) ;
its pass OK but when i display the data on the LCD i got it the 1/3 is shifted and the bottom 2/3 are OK (I am using 800x480 LCD)
Whe i am using bitmap convert to a C file it works 100% without any problem but i have a linked issue if i have too many bitmaps in the code and need them loaded into the external FLASH
Please i am stuck now and cannot continue and i have looked into sample of emWin but without luck, I have been forced by my empolye to search for on other application source but i think that i may lack of misunderstanding your applicaition or its a known issue,
More on my problem - some time when i have reduce the bitmap size it seems to work by i cannot figure it out why, but it works OK on some bitmaps and on others it don't. Something is wrong and i must know it ASAP till end of next week
My mail is ariel@neat-tech.com or arieelahlevy@gmail.com
When i am using :
int iRetValue = GUI_CreateBitmapFromStream565(&bmHorizenSplashScreen,&_pPAL, BMP_LOGO_PTR->data) ; // where the BMP_LOGO_PTR->data is pointing to the DAT area in the RAM
int iRetValue =
