Hello.
Can anybody tell me about support ep9307 on J-Link?
I have old firmware dated from 20 feb. 2006 and all work perfectly. After firmware update i have a lot of mistakes.
For example:
SEGGER J-Link Commander V4.58a ('?' for help)
Compiled Dec 5 2012 18:38:27
DLL version V4.58a, compiled Dec 5 2012 18:38:08
Firmware: J-Link ARM V8 compiled Nov 14 2012 22:34:52
Hardware: V8.00
S/N: 58006516
VTarget = 3.325V
Info: TotalIRLen = 8, IRPrint = 0x0011
Info: CP15.0.0: 0x00000000: Unknown implementer code, Architecure Unknown archit
ecture
Info: J-Link: ARM9, 0 core
****** Error: Bad JTAG communication: Write to IR: Expected 0x1, got 0x0 (TAP Co
mmand : 2) @ Off 0x12.
Found 2 JTAG devices, Total IRLen = 8:
Failed to identify target. Trying again with slow (4 kHz) speed.
Info: CP15.0.0: 0x41129200: ARM, Architecure 4T
Info: CP15.0.1: 0x0D172172: ICache: 16kB (64*8*32), DCache: 16kB (64*8*32)
Info: Cache type: Separate, Write-back, Format A
#0 Id: 0x10920F0F, IRLen: 04, IRPrint: 0x1, ARM920T Core
#1 Id: 0x10920F0F, IRLen: 04, IRPrint: 0x1, ARM920T Core
Found ARM with core Id 0x10920F0F (ARM9)
J-Link>halt
****** Error: Can not read register 9 (R15 (PC)) while CPU is running
PC: (R15) = 00000000, CPSR = 00000000 (Unknown mode, ARM)
****** Error: Can not read register 7 (R7) while CPU is running
****** Error: Can not read register 6 (R6) while CPU is running
****** Error: Can not read register 5 (R5) while CPU is running
****** Error: Can not read register 4 (R4) while CPU is running
****** Error: Can not read register 3 (R3) while CPU is running
****** Error: Can not read register 2 (R2) while CPU is running
****** Error: Can not read register 1 (R1) while CPU is running
mmand : 12) @ Off 0x1C.
Can not read register 0 (R0) while CPU is running
R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
****** Error: Can not read register 14 (R12_USR) while CPU is running
****** Error: Can not read register 13 (R11_USR) while CPU is running
****** Error: Can not read register 12 (R10_USR) while CPU is running
****** Error: Can not read register 11 (R9_USR) while CPU is running
****** Error: Can not read register 10 (R8_USR) while CPU is running
USR: R8 =00000000, R9 =00000000, R10=00000000, R11 =00000000, R12 =00000000
****** Error: Can not read register 16 (R14_USR) while CPU is running
****** Error: Can not read register 15 (R13_USR) while CPU is running
R13=00000000, R14=00000000
****** Error: Can not read register 22 (R12_FIQ) while CPU is running
****** Error: Can not read register 21 (R11_FIQ) while CPU is running
****** Error: Can not read register 20 (R10_FIQ) while CPU is running
****** Error: Can not read register 19 (R9_FIQ) while CPU is running
****** Error: Can not read register 18 (R8_FIQ) while CPU is running
FIQ: R8 =00000000, R9 =00000000, R10=00000000, R11 =00000000, R12 =00000000
****** Error: Can not read register 17 (SPSR_FIQ) while CPU is running
****** Error: Can not read register 24 (R14_FIQ) while CPU is running
****** Error: Can not read register 23 (R13_FIQ) while CPU is running
R13=00000000, R14=00000000, SPSR=00000000
****** Error: Can not read register 25 (SPSR_SVC) while CPU is running
****** Error: Can not read register 27 (R14_SVC) while CPU is running
****** Error: Can not read register 26 (R13_SVC) while CPU is running
SVC: R13=00000000, R14=00000000, SPSR=00000000
****** Error: Can not read register 28 (SPSR_ABT) while CPU is running
****** Error: Can not read register 30 (R14_ABT) while CPU is running
****** Error: Can not read register 29 (R13_ABT) while CPU is running
ABT: R13=00000000, R14=00000000, SPSR=00000000
****** Error: Can not read register 31 (SPSR_IRQ) while CPU is running
****** Error: Can not read register 33 (R14_IRQ) while CPU is running
****** Error: Can not read register 32 (R13_IRQ) while CPU is running
IRQ: R13=00000000, R14=00000000, SPSR=00000000
****** Error: Can not read register 34 (SPSR_UND) while CPU is running
****** Error: Can not read register 36 (R14_UND) while CPU is running
****** Error: Can not read register 35 (R13_UND) while CPU is running
UND: R13=00000000, R14=00000000, SPSR=00000000
Eugeny.
For example:
Hardware: V8.00
S/N: 58006516
VTarget = 3.325V
ecture
J-Link>halt
Eugeny.
