Multiple buffering
  • Multiple buffering
    i am trying to setup my LPC1788 for using Multiple buffering, but so far I enable a second buffer, the screen shows nothing.
    Here is my LCD_X_SHOWBUFFER case:
    case LCD_X_SHOWBUFFER: {
    LCD_X_SHOWBUFFER_INFO * p;
    p = (LCD_X_SHOWBUFFER_INFO *)pData;
    // Calculate address of the given buffer
    BufferSize = (XSIZE * YSIZE * 16) / 8;
    Addr = VRAM_ADDR_PHYS + BufferSize * p->Index;
    // Make the given buffer visible
    LPC_LCD->UPBASE = Addr;
    // Send a confirmation that the buffer is visible now
    GUI_MULTIBUF_Confirm(p->Index);
    return 0;
    I don´t understand, what I am doing wrong.
    Can you please suggest how to do this.
    marsal
  • Hello Adrian,
    Thank you for your reply.
    The "CopyBuffer" function is called after creating the display driver:
    GUI_DEVICE_CreateAndLink(GUIDRV_LIN_16, COLOR_CONVERSION, 0, 0);
    // Set custom callback function for copy operation
    LCD_SetDevFunc(0, LCD_DEVFUNC_COPYBUFFER, (void (*)())_CopyBuffer);
    Here is CopyBuffer function:
    static void _CopyBuffer(int LayerIndex, int IndexSrc, int IndexDst) {
    unsigned long BufferSize, AddrSrc, AddrDst;
    // int i;
    // int BITSPERPIXEL=LCD_GetBitsPerPixelEx(i);
    // Calculate the size of one frame buffer
    // Calculate source- and destination address
    AddrSrc = /*_VRamBaseAddr*/VRAM_ADDR_PHYS + BufferSize * IndexSrc;
    AddrDst = /*_VRamBaseAddr*/VRAM_ADDR_PHYS + BufferSize * IndexDst;
    memcpy((void *)AddrDst, (void *)AddrSrc, BufferSize);
    I have checked all functions and it seems everything be right, but it works not.
    Thank you,
    marsal
    The post was edited 2 times, last by marsal ().
  • Hello marsal,
    I would recommend to follow exactly the steps to implement multiple buffering as they are described in the chapter "Multiple Buffering" in the emWin documentation. Please note the requirements which are also listed there.
    Adrian
  • Hello Adrian,
    I have tried to output a value from "VRAM_ADDR_PHYS" variable in the "_CopyBuffer" function:
    BufferSize = (XSIZE * YSIZE * 16) / 8; // Calculate the size of one frame buffer
    GUI_SetColor(0x7CFC00);
    GUI_DispDecAt(VRAM_ADDR_PHYS,500,30, 10);
    On the screen appears only "-".
    If I print out the Buffer variable, than it appears a right Value of "768000".
    After this function is executed, the board hangs and does nothing from main function.
    Therefore I assume, that "VRAM_ADDR_PHYS" is not defined.
    How can I define the base video RAM address, that is allocated on my LPC1788 board?
    marsal
    The post was edited 3 times, last by marsal ().
