Regarding webserver
  • Dear Venkat,
    You can check if the upload of a file has been successful from a callback defined by your upload form.
    The file will be uploaded to the root directory of your file system and can then be accessed either by
    using the API provided by the file system meant to be used by the web server described in "IP_FS.h"
    or by directly using your typical file system API such as provided by emFile.
    Oliver
