embOS without J-Link
  • embOS without J-Link
    Hi all,
    I would like to know if it is possible to evaluate embOS for ARM without J-Link or x86 without Borland. I downloaded these two trial version, but I just have the arm-elf-gcc and arm-elf-gdb (or gcc and gdb for the x86 version).
    It is possible to compile the small example with GNU tool and then debug it directly with gdb ?
    Thanks a lot
    David LONY
  • Hello David,
    you can also evaluate embOS with embOS simulation. This runs in Windows with Microsoft Visual Studio.
    Another way to use embOS for ARM is using the IAR Embedded workbench and then using the simulator target, if you
    don't want to use real hardware or a jtag emulator like jlink.
    We have a ARM/GNU embOS version, so you can use GNU tools to build the code, but you need a simulator oder real
    hardware with jtag emulator to run embOS.
    Til
