Undefined Weak Reference in mapfile / simulator debugging not possible
  • Undefined Weak Reference in mapfile / simulator debugging not possible
    Hello
    I try to run the segger embOS example for STM32F207 (MB786) in simulator mode with keil UV.
    Versions used:
    * embOS_CortexM_Keil_Trial_V3861
    * Keil UV 4.5
    Compilation works alright, however if I try to start the debugger, it tells me:
    Load "F:\\F\\work\\Segger\\embOS_CortexM_Keil_Trial_V3861\\Start\\BoardSupport\\ST\\STM32F207_MB786\\Output\\Debug\\Start_STM32F207_MB786.AXF"
    *** error 65: access violation at 0x0000000C : no 'read' permission
    Obviously, there is no map entry for various parts of the memory telling the debugger that it is ok to access that memory. Why? I've further tried to add these map entries for the debugger, however, this does not work as code seems to be missing and the simulator just runs through empty code memory space. (using cpu cycles but doing nothing).
    I suspect that this might have to do something with weak pointers to OS functions so that the linker does not include them into the binary.
    In the map file there is a section looking like this:
    Global Symbols
    Symbol Name Value Ov Type Size Object(Section)
    BuildAttributes$$THM_ISAv4$P$D$K$B$S$PE$A:L22UL41UL21$X:L11$S22US41US21$IEEE1$IW$USESV6$~STKCKD$USESV7$~SHL$OTIME$ROPI$EBA8$UX$STANDARDLIB$REQ8$PRES8$EABIv2 0x00000000 Number 0 anon$$obj.o ABSOLUTE
    __ARM_use_no_argv 0x00000000 Number 0 start_ledblink.o ABSOLUTE
    __ARM_exceptions_init - Undefined Weak Reference
    __alloca_initialize - Undefined Weak Reference
    __cpp_initialize__aeabi_ - Undefined Weak Reference
    __cxa_finalize - Undefined Weak Reference
    __rt_locale - Undefined Weak Reference
    __sigvec_lookup - Undefined Weak Reference
    __user_heap_extent - Undefined Weak Reference
    _atexit_init - Undefined Weak Reference
    _call_atexit_fns - Undefined Weak Reference
    _clock_init - Undefined Weak Reference
    _fp_trap_init - Undefined Weak Reference
    _fp_trap_shutdown - Undefined Weak Reference
    _get_lc_collate - Undefined Weak Reference
    _get_lc_ctype - Undefined Weak Reference
    _get_lc_monetary - Undefined Weak Reference
    _get_lc_numeric - Undefined Weak Reference
    _get_lc_time - Undefined Weak Reference
    _getenv_init - Undefined Weak Reference
    _handle_redirection - Undefined Weak Reference
    _mutex_acquire - Undefined Weak Reference
    _mutex_free - Undefined Weak Reference
    _mutex_release - Undefined Weak Reference
    _rand_init - Undefined Weak Reference
    _signal_finish - Undefined Weak Reference
    _signal_init - Undefined Weak Reference
    __Vectors_Size 0x00000184 Number 0 startup_stm32f2xx.o ABSOLUTE
    Stack_Size 0x00000400 Number 0 startup_stm32f2xx.o ABSOLUTE
    __Vectors 0x08000000 Data 4 startup_stm32f2xx.o(RESET)
    __Vectors_End 0x08000184 Data 0 startup_stm32f2xx.o(RESET)
    __main 0x08000185 Thumb Code 8 __main.o(!!!main)
    But perhaps I'm totally mistaken?
    However, does anyone know what is the reason for the simulator failing and how to solve this?
    Thank's very much for any insight.
    Hanspeter
