LCD driver configuration
  • LCD driver configuration
    I'm using emWin, the LCD model I'm using is HSD043I9W1-A, it's not contain in the LCD Driver routine that you provide.
    And now, I don't know how to modify the configuration files and which have to be configured. My LCD circuit connection is eight parallel transmission of data.
    I can drive my LCD with my LCD driver right.
    And the most important problem is that I couldn't get the x- and y- position through the function provided by segger, to determine the position where should I draw .?(
    Thanks a lot.
    Best regards.
    Victor
  • Hello Victor,
    Actually the chapter "Display drivers" in the emWin documentation gives detailed descriptions on how to set up each driver provided by SEGGER. Could you please try to follow the instructions, in the emWin documentation?
    Thank you. If you have any further questions regarding this, please contact SEGGER support.
    Adrian
