hi,
since a few days i try to set up a SDK to program a NXP1768 (ARM LPC1768 Cortex M3 LCD Board from Steitec )
in combination with a J-Link EDU.
The first test was with the open source option --> Yagrato + Eclipse
I've done every step in the yagarto tutorial. I started a new project and imported the example LPC1768Test from the yagrato download section .
The first thing i want do is use the debugging function in combination with the J-Link, i followed the tutorial to configure the debugger.
At configuration point where you have to write down the Initialization Commands, I ve pasted the folowing two listings:
1:
# connect to the J-Link gdb server
target remote localhost:2331
# Set gdb server to little endian
monitor endian little
# Set JTAG speed to 1000 kHz
monitor speed 1000
# Reset the target
monitor reset
monitor sleep 100
# Set JTAG speed in khz
monitor speed auto
# Vector table placed in RAM
monitor writeu32 0xE000ED08 = 0x10000000
2:
monitor reg r13 = (0x10000000)
monitor reg pc = (0x10000004)
break ResetHandler
break main
continue
After that i started the Segger GDB Server (I use Version 4.42a), an now all things are connected. The problem was,
no target connected (red symbol), but i see the target voltage (3,27 V green symbol) an the Jlink was also connected (also green symbol).
What is my mistake?
Then i started debugging and the GDB Server connects to the target (all symbols are green), but i could not step into the code
--> an error occures.
"Execusion is suspended because of error" What is wrong?
The next option I've chosen, was a trial version of IAR Embedded Workbench (btw: V 6.30.2) in combination with J-Link EDU.
I started with a little test project for GPIO operation
Take a look at the sourcecode...
I got errors in the lines where the pins are reseted an set as output. "identifier LPC_OINCON is undefined",
okay, those definition would probably be defined in th header-file!?
Where do i get such headers, from NXP,or is it a part of the IAR workbench or the toolchain?
And how could i add it to the project?
Could i set the port directly, without any definition?
Like you can do it with AVRs, like this
PORT2 |= 0xFF; ???
The last thing i did, was to install a trial version of Keil u Vision,
i started a new project ...again and build it and all went well until i press the load button, then an error occures
here is the log file:
JLink info:
DLL: V4.08b, compiled Jun 30 2009 19:10:31
Firmware: J-Link ARM V8 compiled Feb 8 2012 14:30:39
Hardware: V8.00
S/N : 268002467
OEM : SEGGER-EDU
Feature(s) : FlashBP, GDB
* JLink
JLink Info: Found Cortex-M3 r2p0, Little endian.
JLink Info: TPIU fitted.
JLink Info: ETM fitted.
JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
JLink Error: Unknown OEM - Please obtain an updated version of the JLinkARM.dll from segger.com
so far thats it. I would be very happy if you could help me in this case(s).
It would be very nice when you could help me fix one of these problems,
so that i can start programming.
with best thanks,
sven
1:
monitor speed 1000
# Reset the target
monitor reset
monitor sleep 100
monitor speed auto
2:
break ResetHandler
break main
continue
What is my mistake?
- #include "lpc17xx.h"
- #include "type.h"
- int main (void)
- uint32_t i, j;
- SystemInit();
- //LED = P2[0..7]
- LPC_PINCON->PINSEL4 &= ~(0xFFFF); // Reset P2[0..7] = GPIO
- LPC_GPIO2->FIODIR |= 0xFF; // P2[0..7] = Outputs
- LPC_GPIO2->FIOCLR = 0xFF; // Turn-OFF all LED
- //Loop LED Test
- while(1)
- for(i = 0; i < 8; i++)
- LPC_GPIO2->FIOSET = 1 << i;
- for(j = 1000000; j > 0; j--);
- LPC_GPIO2->FIOCLR = 0x000000FF;
PORT2 |= 0xFF; ???
JLink info:
Hardware: V8.00
S/N : 268002467
OEM : SEGGER-EDU
* JLink
with best thanks,
sven
