passing a pointer to a stack variable to a mailbox
  • passing a pointer to a stack variable to a mailbox
    Hi
    Would there a be problem calling OS_PutMail for a multi byte message, passing it a pointer to a temporary stack variable, for example:
    void aFunction(void)
    short int aMsg = 12345678;
    OS_PutMail(&aMB, &aMsg);
    Lawrence
    No problem, you may use local variables to pass data via mailbox.
    The mailbox stores the data and not the pointer to the data.
    When calling OS_PutMail(), the data which is pointed to by the data pointer is copied into the mailbox buffer, before the OS_PutMail() function is left.
    Armin
