[SOLVED] j-ling debuging in MCUXpresso IDE v10.1.1_606
  • [SOLVED] j-ling debuging in MCUXpresso IDE v10.1.1_606
    I tried do run the j-link debugger with our customer board and the MCUXpresso IDE v10.1.1_606. Unfortunately I get always an error.
    I use an j-link Ultra+ connect to the board with an J-Link 10-pin Needle Adapter (8.06.04).
    The attached picture “J-Link, GDB Server error.PNG”, “J-Link, Launching error.PNG” and “J-Link, GDB Server error screenshot.PNG” are screen shoots of the error.
    The attached file “detail J-Link, GDB Server error.txt” is the error log of j-link.
    Do you have a hint for my?
    best regards
    Dominik Fallmann
  • Hello Dominik,
    Are you trying to debug eval or custom hardware?
    If eval which one?
    Can you connect to the chip using the J-Link commander?
    wiki.segger.com/J-Link_cannot_…ty_using_J-Link_Commander
  • Hello Nino,
    thank you for your swift response.
    We use a custom Hardware. Please, see the attached picture "customer_hardware.png".
    I can use J-Link commander. With my first try a get also an error. Please, see the attached picture "J-Link_Commander1.png".
    From the screenshots the target voltage VTref is suspicously low.
    Are you running the target device in some low power mode?
    For this particular device 3.3 V are usually expected.
    If you run it in low power mode keep in mind that some modes disable debug interfaces so J-Link can't access the device anymore.
    We recommend driving the device at 3.3 V for debugging.
  • Hello Nino,
    thank you for your effort.
    I have found the fault, Pin3 have to connect to GND and at our customer hardware was the Pin3 not connected.
    At the attachment “customer_hardware_Pin3.png” you can find a cut-out of tag-connect datasheet (tag-connect.com/Materials/TC2050-ARM2010.pdf) vs a cut-out from JTAG connector of our hardware.
    best regards
    Dominik
  • Hi Dominik,
