I am trying to use the J-Link Flash loader in the following setup:
Eclipse IDE for C/C++ Developers Oxygen Release (4.7.0)
GNU Tools ARM Embedded(Compiler, Linker)
GDB SEGGER J-Link Debugging plugin
J-Link software V6.30h
J-Link Hardware version: V9.20
Our Cortex-M0 Device
The memory map of device is:
0x00000000-0x0000FFFF: PRAM(Contains the main application)
0x20002000-0x20005FFF: SRAM(Working RAM)
0x60000000-0x607FFFFF: External Flash
I use the flash loader and add support for new devices to the J-Link DLL. This two flash loader(see attachment) can work well in Keil uVision 5 + J-Link.
And here is my JLinkDevices.xml: (see attachment)
<DataBase>
<Device>
<ChipInfo Vendor="SONiX" Name="SNC7312" WorkRAMAddr="0x20002000" WorkRAMSize="0x4000" Core="JLINK_CORE_CORTEX_M0"/>
<FlashBankInfo Name="Code Flash" BaseAddr="0x00000000" MaxSize="0x10000" Loader="Devices/SONiX/SNC7312_PRAM2Flash_160422.FLM" LoaderType="FLASH_ALGO_TYPE_OPEN" AlwaysPresent="1"/>
<FlashBankInfo Name="Data Flash" BaseAddr="0x60000000" MaxSize="0x800000" Loader="Devices/SONiX/SNC7312_SPIFLASH_160421.FLM" LoaderType="FLASH_ALGO_TYPE_OPEN" AlwaysPresent="1"/>
</Device>
</DataBase>
My eclipse based project is in attachment, which memory map is:
Memory Configuration
Name Origin Length Attributes
FLASH 0x00000000 0x00010000 xr
RAM 0x20000000 0x00010000 xrw
CCMRAM 0x10000000 0x00000000 xrw
FLASHB1 0x00000000 0x00000000 xr
EXTMEMB0 0x00000000 0x00000000 xr
EXTMEMB1 0x00000000 0x00000000 xr
EXTMEMB2 0x00000000 0x00000000 xr
EXTMEMB3 0x00000000 0x00000000 xr
MYVARS 0x60020000 0x00800000 xrw
*default* 0x00000000 0xffffffff
Question 1.So far, I can download into PRAM(0x00000000-0x0000FFFF), but can't download into External Flash(0x60000000-0x607FFFFF).I checked memory 0x60020000-0x6002000F in Eclipse memory window or J-Mem V6.30h, it always 0.But it should like this:AddressData0x6002000001 00 00 00 02 00 00 00 03 00 00 00 04 00 00 00
Question 2.
I find error message "PC of target system has unexpected value after Verifying sector. (PC = 0x0000029C)!" in J-Link Log.(see attachment)
Any advice on how to download into the External Flash? I would be grateful for any suggestions.
Best Regards
Wilson
<DataBase>
<Device>
</Device>
</DataBase>
Question 2.
Best Regards
Wilson
