Hello!
I am currently working on a custom design with CC3220S or CC3220SF chip from TI. Currently debugging works under TI's IDE (CCS) with their XDS110 debug probe. We would prefer to use the J-Link, but currenly I am having problems connecting to the unit. Directly within CCS will result in a not very desriptive error message (runJLinkCommand: ERROR: Failed to set device."
I manage to connect to the core with JLinkExe, but this is slightly unreliable -- it works if I switch intermittently to SWD and then back. Any idea what I should do to get this more reliable (or at least JLinkGDBServer to launch reliably?)
$ JLinkGDBServer -device CC3220SF
Checking target voltage...
Target voltage: 3.33 V
Listening on TCP/IP port 2331
Connecting to target...WARNING: Single device found in JTAG chain, but configuration has DRPost = 1, IRPost = 6. These values must be 0 for a single device and will be ignored.
ERROR: CPU-TAP not found in JTAG chain
ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
Shutting down...
Please check power, connection and settings.%
With JLinkExe I can get a connection, but this only after some manual twiddling:
convergens@cvgvmtmpubu:...project/cc3220/sources% JLinkExe -device CC3220SF -if JTAG
SEGGER J-Link Commander V6.30f (Compiled Mar 2 2018 17:30:55)
DLL version V6.30f, compiled Mar 2 2018 17:30:48
Firmware: J-Link V10 compiled Mar 2 2018 17:07:17
Hardware version: V10.10
S/N: 600100729
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
VTref = 3.327V
J-Link>connect
Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
JTAGConf>
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>
Device "CC3220SF" selected.
Connecting to target via JTAG
ICEPick IDCODE: 0x0B97C02F
TotalIRLen = 6, IRPrint = 0x01
WARNING:
ignored.
JTAG chain detection found 1 devices:
#0 Id: 0x0B97C02F, IRLen: 06, TI ICEPick
ICEPick IDCODE: 0x00000000
Cannot read DAP IDCODE. Expected 0xXXXXX477, read: 0x00000000
TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
****** Error: CPU-TAP not found in JTAG chain
Cannot connect to target.
J-Link>if swd
Selecting SWD as current target interface.
J-Link>connect
*** J-Link V6.30f Error ***
Second debugger connection to the same J-Link detected.
J-Link currently uses target interface JTAG while current debugger tries to select target interface SWD.
Should interface be changed?
Connecting to target via SWD
ERROR: Cannot connect to target device
J-Link>if jtag
Selecting JTAG as current target interface.
J-Link>connect
J-Link currently uses target interface SWD while current debugger tries to select target interface JTAG.
TotalIRLen = 10, IRPrint = 0x0011
JTAG chain detection found 2 devices:
#0 Id: 0x4BA00477, IRLen: 04, CoreSight JTAG-DP
#1 Id: 0x0B97C02F, IRLen: 06, TI ICEPick
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
Found Cortex-M4 r0p1, Little endian.
CoreSight components:
ROMTbl[0] @ E00FF000
ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB000 SCS
ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
Cortex-M4 identified.
Shutting down...
S/N: 600100729
VTref = 3.327V
J-Link>connect
JTAGConf>
Speed>
WARNING:
ignored.
J-Link>if swd
J-Link>connect
J-Link>if jtag
J-Link>connect
AP[0]: Core found
