Hi, I'm having issues programming an MK70FN1M0xxx15 processor with
CrossStudio. Basically I can build the project but if I run it or debug
it I get a failure saying "Failed to download application.
Generic error." and also an "Timeout while checking target RAM, RAMCode did not respond in time in CrossWorks" error.
I then can use J-Flash to program the device using the same debugger
and then can use attach to running application in CrossStudio to
actually debug the project.
Clicking download an s19 file doesn't work either, but reset does work from CrossStudio.
If I program another project using a different processor (VF5xxR_A5) everything works.
I tried using other working segger debuggers and they don't work either. Using a CrossConnect debugger does work though.
Thanks!
Thanks!
