I am using J-Link and the GDB server for debugging ARM devices under Eclipse with GCC tool chain. I added external RAM to my linker script an realized that when loading my code with the debugger the complete external RAM section will be be loaded with data. Even though this RAM section does not need to be initialized with any data at all. I assume that J-Link is doing that for whatever reason. Is there a way to avoid that because it exceeds the download time quite significantly.
Any help on that is appreaciated.
