[ABANDONED] JLINK GDB and ARM MCU Eclipse for MX7D M4
  • [ABANDONED] JLINK GDB and ARM MCU Eclipse for MX7D M4
    Hello everyone,
    after being able to connect to my target hardware (i.MX7D) using JLink.exe I wanted to integrate the JLINK in ARM MCU Eclipse.
    I configured Eclipse based on gnu-mcu-eclipse.github.io/debug/jlink/
    ON starting a debug session, Eclipse creates an error:
    J-Link GDB Server failed:
    Could not connect to target. Please check if target is powered and if ribbon cable is plugged properly.
    For more details, see the JLinkGDBServerCL.exe console.
    and my console outputs the following:
    SEGGER J-Link GDB Server V6.22g Command Line Version
    JLinkARM.dll V6.22g (DLL compiled Jan 17 2018 16:39:42)
    Command line: -if swd -device MCIMX7D7_M4 -endian little -speed 100 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    GDBInit file: none
    GDB Server Listening port: 2331
    SWO raw output listening port: 2332
    Terminal I/O port: 2333
    Accept remote connection: localhost only
    Generate logfile: off
    Verify download: on
    Init regs on start: on
    Silent mode: off
    Single run mode: on
    Target connection timeout: 0 ms
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: MCIMX7D7_M4
    Target interface: SWD
    Target interface speed: 100kHz
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V10 compiled Jan 11 2018 10:41:05
    Hardware: V10.10
    S/N: 50117772
    Feature(s): GDB
    Checking target voltage...
    Target voltage: 1.81 V
    Listening on TCP/IP port 2331
    Connecting to target...WARNING: CPU could not be halted
    Halting target device failed. Trying again with reset
    Failed to halt target device on connect
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
    Please check power, connection and settings.
    Any idea why this might happen? I realized there is no script file attached.
    Interesting is the target device that is listed as MCIMX7D7_M4, because in the project settings i have selected an MCIMX7D2 type. Manually changing the projectname_debug.launch file to the D2 results in
    Failed to set device (MCIMX7D2_M4). Unknown device selected?ERROR : Failed to set device.
    On the Segger compatible devices page, i dont see the MX7 being listed. May the JLink not be used with an MX7 in eclipse?
    ____________
    On changing the device from M4 to A7_0 (without actually changing the project settings or target core or anything else) i get the following output (that doesnt work as expected, but connects at least):
    Command line: -if swd -device MCIMX7D5_A7_0 -endian little -speed 100 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    J-Link script: none
    Target device: MCIMX7D5_A7_0
    Connecting to target...ERROR: Cortex-A/R-SWD (connect): Could not identify core via peripheral ID registers.
    Connected to target
    Waiting for GDB connection...Connected to 127.0.0.1
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0xE59FF018)
    Received monitor command: speed 1000
    Target interface speed set to 1000 kHz
    Received monitor command: clrbp
    Received monitor command: reset
    Resetting target
    Received monitor command: halt
    Halting target CPU...
    ...Target halted (PC = 0x00000C60)
    Received monitor command: regs
    Received monitor command: speed auto
    Select auto target interface speed (1000 kHz)
    Received monitor command: flash breakpoints 1
    Flash breakpoints enabled
    Received monitor command: semihosting enable
    Semi-hosting enabled (SVC Addr = 0x08)
    Received monitor command: semihosting IOClient 1
    Semihosting I/O set to TELNET Client
    Received monitor command: SWO DisableTarget 0xFFFFFFFF
    SWO disabled successfully.
    Received monitor command: SWO EnableTarget 80000000 1000000 0x1 0
    SWO enabled successfully.
    WARNING: Failed to read memory @ address 0x00000C60
    Downloading 12 bytes @ address 0x00008000 - Verify failed
    [.. multiple failed attempts ..]
    Writing register (PC = 0x0000800C)
    Resetting target
    ...Target halted (PC = 0x10084000)
    WARNING: Failed to read memory @ address 0x0000800C
    [.. multiple commands ..]
    Starting target CPU...
    ERROR: Could not start CPU core. (ErrorCode: -1)
    WARNING: Mis-aligned memory read: Address: 0xFFFFFFFF, NumBytes: 4, Alignment: 4 (Word-aligned)
    WARNING: Failed to read memory @ address 0x10084000
  • Some additional info:
    I enabled log file output.
    From the log file:
    02-00000000-00-00000306-01E9: Found Cortex-M4 r0p1, Little endian. -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_ReadMem(4 bytes @ 0xE0002000)
    [.. many more romtbl reads ..]
    02-00000000-00-00000310-00A2: T2448 000:310 JLINK_GetIdData(...) >0x0D TIF> >0x21 TIF> ScanLen=4 NumDevices=1 aId[0]=0x5BA02477 aIrRead[0]=0 aScanLen[0]=0 aScanRead[0]=0 (0001ms, 0308ms total)
    02-00000000-00-00000310-0048: T2448 000:311 JLINK_GetDeviceFamily() returns 14 (0000ms, 0308ms total)
    02-00000000-00-00000310-004D: T2448 000:311 JLINK_CORE_GetFound() returns 0xE0000FF (0000ms, 0308ms total)
    02-00000000-00-00000310-0044: T2448 000:311 JLINK_IsHalted() returns ERROR (0000ms, 0308ms total)
    03-00000000-00-00000310-0023: ERROR: Could not connect to target.
    03-00000000-00-00000310-0035: Target connection failed. GDBServer will be closed...
    03-00000000-00-00000321-0037: Restoring target state and closing J-Link connection...
    02-00000000-00-00000321-0041: T2448 000:322 JLINK_IsOpen() returns 0x01 (0000ms, 0308ms total)
    02-00000000-00-00000321-0058: T2448 000:322 JLINK_ExecCommand("ClrAllBPs", ...). returns 0x00 (0000ms, 0308ms total)
    03-00000000-00-00000341-0010: Shutting down...
  • I have found out how to add a script file based on wiki.segger.com/Eclipse
    This is the output for the SABRE board:
    J-Link script: C:\Eclipse_MCU_And_Toolchains\JLink\File_NXP_iMX7D_Connect_CortexM4.JLinkScript
    eature(s): GDB
    Target voltage: 3.33 V
    Connecting to target...ERROR: Error while compiling J-Link script file: Error while compiling. Line 1, column 8:
    <!DOCTYPE html>
    Pragma unknown
    Bad JTAG communication: Write to IR: Expected 0x1, got 0xF (TAP Command : 10) @ Off 0x5.
    Could not find core in Coresight setup
    Ant output for our custom board (giving a different error):
    <!DOCTYPE html>
    Pragma unknown
    J-Link found 1 JTAG device, Total IRLen = 4
    JTAG ID: 0x5BA00477 (Cortex-M4)
    <!DOCTYPE html>
    Pragma unknown
    The JLinkScript you are using, is it from the J-Link software install folder?
    Did you modify the JLinkScript in some way?
    What J-Link software version are you using in Eclipse? Make sure it is the latest one and that you use the JLinkScript from the install folder.
  • The JLinkScript you are using, is it from the J-Link software install folder?
    I used a downloaded the version from your wiki page. I checked the content of the downloaded version ... it was actually a web page and not a script so I probably screwed up the file download.
    Switched to the script in the install folder.
    Nope.
    First console output in OP:
    should be the latest version. Was downloaded a few days ago._____________________________
    What is interesting as well:
    Error when i try to debug the M4 on the Sabre board:
    "Feature(s): GDB
    Target voltage: 3.32 V
    Connecting to target...ERROR: Bad JTAG communication: Write to IR: Expected 0x1, got 0xF (TAP Command : 10) @ Off 0x5.
    ERROR: Could not connect to target."
    While trying to debug on the M4 on custom hardware a different error occurs:Feature(s): GDB
    Connecting via JLink.exe and not through Eclipse:
    SABRE:
    Speed>300
    Device "MCIMX7D7_M4" selected.
    Connecting to target via JTAG
    J-Link script: iMX7D Cortex-M4 core J-Link script
    TotalIRLen = 4, IRPrint = 0x01
    JTAG chain detection found 1 devices:
    #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP
    AP map detection skipped. Manually configured AP map found.
    AP[0]: AHB-AP (IDR: Not set)
    AP[1]: APB-AP (IDR: Not set)
    AP[2]: CUSTOM-AP (IDR: Not set)
    AP[3]: CUSTOM-AP (IDR: Not set)
    AP[4]: AHB-AP (IDR: Not set)
    AP[4]: Skipped. Could not read CPUID register
    AP[4]: Skipped. No ROM table (AHB-AP ROM base: 0x00000000)
    ****** Error: Bad JTAG communication: Write to IR: Expected 0x1, got 0xF (TAP Command : 10) @ Off 0x5.
    CUSTOM:
    Specify target interface speed [kHz]. : 4000 kHz
    Speed>300
    Device "MCIMX7D3_M4" selected.
    AP[4]: Core found
    AP[4]: AHB-AP ROM base: 0xE00FF000
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    ROMTbl[0][7]: E0043000, CID: B105900D, PID: 001BB908 CSTF
    ROMTbl[0][8]: E0044000, CID: B105900D, PID: 004BB906 CTI
    Cortex-M4 identified.
    Most of all i wonder why the results between the sabre and the custom board are different. I mean, ofc they can be different as in the custom hardware doesn't work as intendet ... but I'd expect the SABRE to work rather well.What may or may not be important:
    Our custom hardware actually uses an MX7D2... device. Only D3, D5 and D7 are available in the jlink tools.
    Any ideas on what might be going wrong?[/size]
    The post was edited 3 times, last by LHE ().
  • And some more info:
    The SoC has two external reset signals:
    TRST# and POR# (jtag reset and power on reset).
    On the custom board, TRST is connected to the JTAG header and the processors TRST pin.
    POR is connected to a PMIC (open drain), the processors POR pin and to TRST via shottky diode (to prevent overvoltage on the POR pin in case the emulator has been set up incorrectly).
    JTAG is running on 1V8.
    POR was 2V2 with the diode attached and 3V3 with the diode removed.
    Means i cannot have the 2 pins connected.
    based on figure 4-36 (reset system) in the MX7 datasheet I understand it does not really matter if POR or TRST are pulled low, as they are connected to the internal system via AND. I am just wondering if this AND can operate correctly if one input is 1V8 and one is 3V3 ...
    With the diode removed, the JLINK pulls down TRST for 20ms (and the processor may or may not reset). I guess I have to figure out how to fix this in hardware?!
    Thanks!
    The post was edited 1 time, last by LHE ().
  • Alright, I have added 2 FETs so the reset signals are on 1V8 / 3V3 and get pulled down correctly.
    However, the error remains ..
    Feature(s): GDB
    Shutting down...
    C:\Program Files (x86)\SEGGER\JLink_V622g>
  • i.MX7D connect to M4 / A7 - not halted / waiting for GBD connection
    Hello again,
    after kind of adding information all over the place in my last thread i decided to simply create a new one.
    The current state is:
    I seem to not be able to connect to the MX7's M4.
    I have attached the log files for the following four scenarios:
    - connect to the NXP SABRE A7_0
    - connect to the NXP SABRE M4
    - connect to the CUSTOM BOARD A7_0
    - connect to the CUSTOM BOARD M4
    On both boards, connecting to the A7 seems to work well.
    Connecting to the M4 ends in different error messages for the two boards, but at least on the custom board the M4 is found in the JTAG chain. However, it can not be halted.
    I am wondering ... do I need to run the scripts for A7_0, A7_1 and M4 one after another? Or is it okay to run only the M4 script file?
  • *This thread has been merged with a previously opened thread for the same topic.*
    I merged this thread to keep information at one place. Please do not open new threads with the same topic even if it got "messy".
    Try to keep information at one place.
    You only need to run the M4 Script file to connect to the M4.
    Attached is the J-Link Commander output I get with our SABRE board.
  • Try to keep information at one place.
    Understood!
    I tried to connect to the board with and without SD card (including uboot/Linux).
    With SD card, i cannot connect to the M4 using JLink.exe and JLinkGDBServerCL.exe. Outputs have been attached.
    After removing the SD card and doing a power cycle, JLink.exe is able to identify the M4.
    JLinkGDBServerCL still comlpains about not being able to halt the CPU. Log file has been attached.
    I realized you are using version 6.30, while I am using version 6.22 so I installed v6.30b.
    On opening JLink I was asked to update the Emulators firmware. The Firmware update timed out and I am no longer able to connect to the JLink. :|
    "Cannot connect to J-Link via USB.
    Failed to connect.
    Could not establish a connection to the J-Link".
    So .. what do I do now?
    Happened when opening JFlash.exe. On opening JLink.exe I was asked to update the firmware again, this time the update completed.
    I can still not connect to the M4 using the GDBServerCL, as the target CPU cannot be halted.
    The post was edited 2 times, last by LHE ().
  • I have found a ressource in the NXP Forum that describes/achieved what I want to do.
    After adjusting the startup and debugging options as described I no longer get the previous error when starting a debug session in Eclipse.
    Screenshots of the settings are attached.
    But I run into a different problem now:
    Error in services launch sequence
    Starting J-Link GDB Server timed out.
    I have already adjusted the timeout setting as described here , but no success.
    No difference if running Eclipse as an admin. Path to the GBDServerCL is set up correctly/automatically by Eclipse.
    Any ideas on what might be missing or setup wrong?
    Thanks and regards!
  • With the script provided in the NXP Forum thread mentioned in my previous post I am able to have the JLinkGDBserver connect to the M4, waiting for the GDB connection.
    So I think this part is all good now. I just dont know how to get the GDB connection up.
    When I started the JLinkGDBServer through the win command prompt and then start e debug sesion in eclipse, the session is started. But i do not see any debug output. Or any other hint for the system to be alive.
  • Alright, some more information:
    The debug process did not start because the Eclipse settings pointed to the JLinkRemoteServerCL.exe instead of the JLinkGDBServerCL.exe.
    A debug session is now created but i do not see any output.
    When switching to the JLink Control Panel - CPU Regs tab and click "read all registers" the following result is shown:
    I guess these registers should be initialized by .. probably eclipse, through jlink? Not sure if this being 0 is a result of:
    - Jlink misconfiguration
    - Eclipse misconfiguration
    - Read error
    How are these registers usually set up? I assume Eclipse would need to tell the Jlink what these registers should be set to?
    What Eclipse IDE are you using currently?
    How are you calling the JLinkGDBServer.exe exactly?
    I see that you use some modified version of the JLinkScript for the M4 core. Could you attach it? What does it do differently then the one in the J-Link software package?
    How to properly set up Eclipse for J-Link is described here: segger.com/products/debug-prob…/technology/ides/eclipse/
    Make sure that you followed the linked tutorials step by step. Should you configure something differently it might not work.
    Please understand that we can't put much time into this as J-Link is connecting correctly to the target with GDBServer and using our other tools. The Eclipse Plugin is not maintained nor supported by us. Please contact the plug in maintainer if the linked setup guide on our website does not work.
  • Please understand that we can't put much time into this as J-Link is connecting correctly to the target with GDBServer and using our other tools. The Eclipse Plugin is not maintained nor supported by us. Please contact the plug in maintainer if the linked setup guide on our website does not work.
    Ye sure, I am aware of that.
    So far, I am not entirely sure if this is an issue that can be resolved on the JLink side or not.
    Probably not, but Ill keep posting here until this is resolved for the unlikely case of someone having the same struggles.
    The latest problem was that I had not added a linker script file that was provided as part of the board support package in the Eclipse settings under
    Project Preferences - C/C++ Build - Settings - GNU ARM Cross C Linker - General - Script files
    After adding this, the .elf file grew from 33kB to 2900kB.
    I can start a debug session using the "JLinkGSBServer" and "arm-none-eabi-gdb.exe" and through eclipse.
    However, there is still one problem:
    The CPU cannot be halted properly. It halts just once at startup, but then it does not halt ever again.
    Eclipse is setting up a breakpoint at main(), and the console output shows
    Setting breakpoint @ address 0x202141A6, Size = 2, BPHandle = 0x0001
    Debugger requested to halt target...
    I assume the debugger halt request is the breakpoint that is hit, but the CPU does not care.
    Can the (not) halt behaviour be influenced through the jlink tools? Is this behaviour known for the MX7's M4?
    I am not sure if changes onthe jlink side could help with this or not.
    I had run into the "CPU could not be halted" problem before, it kept me from starting any debug session until I found the customized script.
    it adds a cutom function to reset the target and is attached to this thread: community.nxp.com/thread/461296
    From the JLinkGDB log file, with the custom script:
    T1374 000:250 JLINK_IsHalted() returns FALSE (0002ms, 0248ms total)
    T1374 000:252 JLINK_Halt()CPU could not be halted returns 0x01 (0004ms, 0250ms total)
    T1374 000:256 JLINK_Reset() J-Link Script File: Executing ResetTarget() ***** Custom ResetTarget called ***** Performing customized ResetType 0 *** -- CPU is running -- CPU_WriteMem(4 bytes @ 0x3039000C) -- CPU is running -- CPU_WriteMem(4 bytes @ 0x00180000) -- CPU is running -- CPU_WriteMem(4 bytes @ 0x00180004) -- CPU is running -- CPU_WriteMem(4 bytes @ 0xE000EDFC) -- CPU is running -- CPU_WriteMem(4 bytes @ 0x3039000C)T-bit of XPSR is 0 but should be 1. Changed to 1.
    -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDFC) -- CPU_ReadMem(4 bytes @ 0xE0001000) (0033ms, 0283ms total)
  • JLink.exe has an TestHaltGo command.
    When connecting to the A7_0 core, 1000 halt/go cycles are done within ~3,5s and no problem occurs.
    On trying the same test while connected to the M4 i simply get "WARNING: CPU could not be halted".
    I do not know if this is a hardware/layout problem, Jlink problem, silicon problem or setup problem.
    (Although i can probably exclude layout problem, as i see the same behaviour on three different hardware platforms, one being the SABRE).
    I am absolutely stuck here. Any advice is very welcome.
    Well helloouu there, friend. :P
    Just a quick question: do you know that M4 is enabled & running before you connecting to it and trying to halt?
  • Hello!
    Well when opening the JLink conrtol panel - CPU Regs - Read all registers (after starting a debug session) the console prints: ERROR: Can not read register 20 (CFBP) while CPU is running
    So I guess its running.
  • Interestingly, everything seems to work fine when using GDB command line tools (at least: uploading binarys).
    However i cannot really execute them.
    Even using the example projects that come with batch files for building (just needed to install MinGW and cmake) I cannot get the CPU running properly.
    The program counter seems to always get out of hand and points to some reserved.
    By setting manual breakpoints, I can see that the Reset_Handler routine is called, but the CPU never gets to the main thread.
    I have tried this using:
    * MX7 driver example - UART polling
    * GPIO IMX example
    * MX7 driver example - UART polling with recreating the project in a custom eclipse environment
    They all show the same behaviour.
