Hello
I'm facing problems at the moment with my Flasher ARM. In production every second flashing action fails.
I found out that after sucessfully flashing it doesn't disconnect automatically from the target. That is the reason why it fails at the next chip.
The J-link userguide tells me that there should be an option in the global settings "disconnect after each operation".
Unfortuantely this check box doesn't exist in the latest version of SEGGER J-Flash (I am using V6.22g).
can anyone tell what i can do that it disconnects after each programming action automatically?
Thank you very much
BR Mario
Thank you very much
BR Mario
