Hi there,
i am using the J-Link Commander to flash my EFM32
I wrote a little batchfile for the commander to automate the process. A CommanderScript passes the right commands. It looks like this.
So I log the process in the logfile. My Problem is, how can I detect a successful flashing/verification? Is there any line/option that I can read out to verify that the new firmware is on my board? There is an environment variable %ERRORLEVEL% but as far as i know, it only shows that the JLink.exe finished successfully, but doesn´t show the flashing/verifycation result.
A different approach I have in mind would be to add a further step to read out the FW with savebin and then make a checksum with FCIV against the myTestFW.bin file.
Do you have any other suggestion?
cheers
max
cheers
max
