[SOLVED] IAR with remote J-link ARM GDB server
  • [SOLVED] IAR with remote J-link ARM GDB server
    I can't run IAR with remote J-link ARM GDB server on Raspberry Pi
    I got message: Busy or Flash loader reported error. Here is logged all communications.
    Is it configuration mistake ?
    • log.zip
      (119.44 kB, downloaded 233 times, last: )
    What exactly is your setup?
    Is your host PC the raspberry pi?
    How is the J-Link connected to it.
    Where is IAR installed and what version are you using?
    What exactly are you trying to achieve with your setup?
    Is the STM32 the target device you are trying to program?
    Thank you for clarifying your setup.
    Generally the setup you are trying to achieve should be possible from J-Link side. According to IAR documentation however the IAR GDB functionality only supports OpenOCD.
    So it seems like JLinkGDBServer is not supported by IAR.
    Please contact IAR in that regard for further support.
    To make your setup work anyways without the need for GDB we suggest getting a J-Link PRO: segger.com/products/debug-probes/j-link/models/j-link-pro/
    This one has a Ethernet port which can be used for debugging. So you can connect the J-Link PRO per Ethernet into the same subnet as your PC and you can debug directly without the need of the Raspberry PI and GDB.
    Would that be of interest for you?
    You can also trade in your J-Link Plus to get a discount on the J-Link PRO: segger.com/purchase/trade-in-program/
    You wrote that you have a high voltage environment. For that purpose we offer isolation adapters as well to protect J-Link from overvoltages: segger.com/products/debug-prob…ories/isolators/overview/
