How to get image pressed event if window has two images which are same size and same position ?
  • How to get image pressed event if window has two images which are same size and same position ?
    Hi everybody!
    My project have a window which has two images.
    These images have same size, same position (at the center of window) and I call them as image_1 and image_2.
    Firstly, I set image_1 with bitmap data bmp11, image_2 with bitmap data bmp_21.
    Then, when I press on image_1, I want to change the bitmap data of both image_1 and image 2. from bmp11 to bmp12 for image_1 and from bmp21 to bmp22 for image_2.
    The problem is that when I press on image_1, the data of those images are not changed. It seems I can not catch the image_1 pressed event. I guess that happens because image_1 and image_2 are in the same position and size.
    Could you please help me to fix this problem? I also attach my source code for you to check.
    Thank you!
    • Test.zip
      (23.85 kB, downloaded 190 times, last: )
    Yes you are right. The topmost widget image_2 catches the input and it never get through to image_1.
    Attached is your example with a small change which makes it working. You can either react on release of image_2 or react on both widgets in the 'same' case. Search for '/****/' to find my changes.
    I had a good laugh once it was working. Didn't expected such an image.
    Another point is that you set an empty BMP data. It is working but I don't recommend to do this. Better would be to set simply no image for image_2.
    • Test.zip
      (22.63 kB, downloaded 209 times, last: )
