How to create a custom parametized widget
  • How to create a custom parametized widget
    I need a custom widget. I read "AN03002 Custom Widget Type Creation Guide". Since my custom widgets are made up of several child widgets I used the message WM_CREATE in the callback, as described in "UM03001 User & Reference Guide for emWin V5.40" 18.6.2:
    [img]https://s7.postimg.org/3re220x1n/STem_Win540_WM_CREATE.jpg[/img]
    The problem is that my widget must be parameterized. For example, depending on the value of a parameter my wigdet can have 2 or 4 child widgets.
    How can I pass these parameters to the WM_CREATE message?
    best regards
    Max
    It is possible to set user data for a window with WM_SetUserData() and receive them with WM_GetUserData(). Unfortunately this user data won't be available when the WM_CREATE message appears.
    In the latest version of emWin (5.44) we have added a message (WM_USER_DATA) which will automatically send to a window and allows the user to react on data. With older version you have to do it on your own with a user message.
    Instead of reacting on WM_CREATE to create the child widgets you can react on the message send after setting the user data. This will allow you to use the parameter in the user data to create the child widgets.
    Attached is an example on how this could be done.
    • SetUserData.zip
      (837 Byte, downloaded 344 times, last: )
