[SOLVED] moving an existing solution
  • [SOLVED] moving an existing solution
    Hi all,
    I am using an example solution from nordic sdk 14.1. It
    works fine. But I wanted to move the entire solution two directories up.
    My problem is that all resources files are declared in the
    .emProject file with a relative path which is not correct anymore:
    ../../../../../../components/ which should now be
    ../../../../components.
    My question is: can I easily change the path
    inside embedded studio? The only solution I found for now, was to
    manually modify the .emProject file...
    Thank you for your help!
    Currently there is no other option than to edit the .emproject file manually.
