[SOLVED] J-Link error - "Could not measure total IR len. TDO is constant high." SWD stuck in reset
  • [SOLVED] J-Link error - "Could not measure total IR len. TDO is constant high." SWD stuck in reset
    I am trying to use J-Link to debug my custom board with arm microcontroller - LPC2148FBD64-S.
    I am using SEGGER J-Link Commander V6.20h with Firmware: J-Link Pro V4.
    S/N : 174403384
    When trying to use the JTAG debugger I get the error - Could not measure total IR len. TDO is constant high.
    I do read Vtref close to 3.3V as expected.
    So, when I couldn't get the JTAG to communicate with the board, I tried SWD and this time Jlink driver tries to download the application on the board, but it just gets stuck in the reset handler and I just see the debugger stopping at the reset vector line of code in my cstartup file.
    Also find attached the debug log when I used the SWD.
    SWD.txt
    Do you have any suggestions for a fix or what the problem might be?
    Thanks.
    The post was edited 1 time, last by burn ().
    The described behaviour is rather odd.
    Was the J-Link working on another target?
    Do you have an eval board with the particular chip to test against?
    Could you please post the full Commander output when trying to connect?
    How is JTAG/SWD wired on your custom board?
  • Hi Nino,
    The Jlink has been working for another board that I used for other applications. It had the same microcontroller LPC2148.
    I have 8 pin JTAG connection available on the board. So I just use the 3.3V, nTrst, TDI, TMS, TCK, TDO and GND pins from the 20 pin JTAG.
    Find below the debug outputs
    Thanks!
    The error output you are seeing suggest that the JTAG connection is physically not connected properly.
    At least TDO is not wired as expected and is pulled constantly high.
    Please check your physical debug connection again and if all for JTAG needed connections are present.
