[SOLVED] Possible to integrate a MISRA C checking external tool?
  • [SOLVED] Possible to integrate a MISRA C checking external tool?
    Hi, I'm Matthew. I use SES 3.24 on 64-bit Windows 10 machine & MacBook Pro Sierra 10.12.
    In the SEGGER's web page , it says that
    External Tools
    For further analysis of your code, for example to run a MISRA check on your sources, Embedded Studio features the inclusion of external tools.
    You can add commands to be executed and run them on your project items.
    The tool output is shown in the log window, and for tools such as Lint you can jump directly to reported source lines."
    As shown in the Wiki page about C/C++ List of tools for static code analysis,
    I had
    - Lint
    - PC-Lint
    - Splint
    in my mind and I was wondering whether one of it can be included as an external tool to check MISRA C compliance.
    Is there a documentation or a demo about SES including these external tools to check MISRA C compliance?
    -Best Regards
    -Best Regards, Matthew
  • Hello Matthew,
    If you want to use Lint for example you only need to configure the global macro settings to link the Lint directory.
    You can do so as follows:
    - Go to Tools->Options...->Building->Build->Global Macros
    - Edit the entry to: LINTDIR=c:/Lintinstalldirectory
    - Save entry
    For "c:/Lintinstalldirectory" you enter wherever you have Lint installed to.
    To use the tool simply right click your source coude Tools->Run Lint
    There is currently no official documentation for this implementation but will follow shortly.
    For orientation how to implement other tools than lint you can use the tools.xml as reference.
    You can access it at: File->Open Studio Folder...-> External Tools Configuration
    Hi, Nino. I see.
    Hope to see the official document soon.
    It would be nice if the document demonstrates the configuration using PC-Lint or Splint on a Windows 10 or MAC pc.
    -Best Regards
  • Hi Matthew,
    This is definitely on our todo list and we will be making a tutorial on our wiki that explains the setup step by step.
    Thanks, Nino! I'm new to the forum. I don't know whether a "close thread" feature.
    Anyways, the case is solved. I deeply appreciate your hard work and let's close this thread.
    -Best regards
  • Hi Matthew,
    Don't worry, we the mods do the closing only if a question has been answered or a close requested by the user :)
    Thank you for the flowers.
    I will consider this question as solved then.
