Hello all,
I am new to emWin so i have my first issues with an application that i am trying to develop.
In my main window I want to use a knob widget to select one of the next windows that i want to open.
In the main window i use one 480x272 image as background and the know image 154x154, they are defined in different c files as
In the attached image you can see that the know has some rendering issues that i am not able (don't know how) to fix them and this is the reason i am asking here for help and ideas.
The second issue is that i cant find any example on how to:
- create an new window based on the selection from the main screen
- on the new window if i press a button i want to close it and go back to main window.
I did found examples with virtual screens and frames and use them. I have managed to create the new window, close it using GUI_EndDialog, but once i get back to the main window the widgets are not responding.
Thank you.
- #include #include "GUI.h"#ifndef GUI_CONST_STORAGE #define GUI_CONST_STORAGE const#endifstatic GUI_CONST_STORAGE unsigned long _acBackGround[] = {....};GUI_CONST_STORAGE GUI_BITMAP bmBackGround = { 480, 272, 1920, 32, (unsigned char *)_acBackGround, NULL, GUI_DRAW_BMP8888};static GUI_CONST_STORAGE unsigned long _acKnob[] = {...};GUI_CONST_STORAGE GUI_BITMAP bmKnob = { 154, 154, 616, 32, (unsigned char *)_acKnob, NULL, GUI_DRAW_BMP8888};
- #include "MainScreen.h"#include "DIALOG.h"#include "myResources.h"#include
- #define IcoSize 32#define BtnSize 40#define AMP_COLOR_BLUE 0x0237e1#define AMP_COLOR_GRAY 0xFF4D4B4C#define KNOB_X 163#define KNOB_Y 85#define FONT_EXPLANATION &GUI_Fontlcdphone13char myStr[10];static const GUI_BITMAP * _bntIco[] = {&bmScreenOff, &bmXBee, &bmPlay};typedef struct BITMAP_ITEM BITMAP_ITEM;struct BITMAP_ITEM{ const GUI_BITMAP * pBitmap; const char * pText; U16 xPos; U8 yPos; U16 imgId;};static const BITMAP_ITEM _aBitmapItem[] = { {&bmHand, "MANUAL", 115, 207, ID_Hand}, {&bmBulb, "BULB", 102, 172, ID_Bulb}, {&bmTimeLapse, "TIME LAPSE", 99, 135, ID_TimeLapse}, {&bmHDR, "HDR", 108, 99, ID_Hdr}, {&bmIR, "IR", 127, 67, ID_Ir}, {&bmTriggrered, "TRIGGERED", 154, 42, ID_Triggrered}, {&bmDarkRoom, "DARK ROOM", 187, 26, ID_DarkRoom}, {&bmLightning, "LIGHTINING", 224, 21, ID_Lightning}, {&bmBullet, "BULLET", 261, 26, ID_Bullet}, {&bmDrops, "DROPTLETS", 294, 42, ID_Drops}, {&bmPanManual, "MANUAL P&T", 321, 67, ID_ManualPT}, {&bmPanAuto, "AUTO P&T", 340, 99, ID_AutoPT}, {&bmStarTracker, "STAR TRACKER", 349, 135, ID_StarTracker}, {&bmUSB, "USB", 346, 172,ID_USB}, {&bmSettings, "SETTINGS", 333, 207, ID_Settings},};typedef struct Coord Coord;struct Coord { U16 xPos; U8 yPos;};static const Coord _LedPos[] = {{156, 201},{147, 176},{145, 149},{152, 123},{165, 100},{185, 82},{209, 71},{235, 67},{261, 71},{285, 82},{305, 100},{318, 123},{325, 149},{323, 176},{314, 201},};static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = { { WINDOW_CreateIndirect, "", ID_WINDOW_0, 0, 0, 480, 272, WM_CF_SHOW | WM_CF_MEMDEV, 0, 0 }, { KNOB_CreateIndirect, "", GUI_ID_KNOB0, 163, 85, 154, 154, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Hand, 115, 207, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Bulb, 102, 172, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_TimeLapse, 99, 135, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Hdr, 108, 99, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Ir, 127, 67, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Triggrered, 154, 42, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_DarkRoom, 187, 26, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Lightning, 224, 21, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Bullet, 261, 26, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Drops, 294, 42, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_ManualPT, 321, 67, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_AutoPT, 340, 99, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_StarTracker,349, 135, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_USB, 346, 172, IcoSize, IcoSize, WM_CF_SHOW }, { IMAGE_CreateIndirect, "", ID_Settings, 333, 207, IcoSize, IcoSize, WM_CF_SHOW }, { BUTTON_CreateIndirect, "", ID_BUTTON_0, 10, 230, BtnSize, BtnSize, WM_CF_SHOW }, { BUTTON_CreateIndirect, "", ID_BUTTON_1, 80, 230, BtnSize, BtnSize, WM_CF_SHOW }, { BUTTON_CreateIndirect, "", ID_BUTTON_2, 400, 230, BtnSize, BtnSize, WM_CF_SHOW }, { TEXT_CreateIndirect, "", ID_TEXT_0, 200, 240, 120, 20, WM_CF_SHOW }, };static void _DrawScale(KNOB_Handle hKnob, TEXT_Handle hText){ U8 Value; Value = 14 - (KNOB_GetValue(hKnob) / 170); TEXT_SetText(hText, _aBitmapItem[Value].pText); GUI_DrawBitmap(&bmLED, _LedPos[Value].xPos, _LedPos[Value].yPos);}static void _DrawKnob(GUI_MEMDEV_Handle hMem) { int xSizeMem, ySizeMem;
- xSizeMem = GUI_MEMDEV_GetXSize(hMem); ySizeMem = GUI_MEMDEV_GetYSize(hMem); GUI_AA_PreserveTrans(1); GUI_MEMDEV_Select(hMem); GUI_SetBkColor(GUI_TRANSPARENT); GUI_Clear(); GUI_SetPenSize(3); GUI_SetColor(AMP_COLOR_BLUE); GUI_AA_DrawLine(xSizeMem / 2 + 10, ySizeMem / 2, xSizeMem / 2 + xSizeMem / 3, ySizeMem / 2); GUI_SetPenSize(1); GUI_MEMDEV_Select(0); GUI_AA_PreserveTrans(0);}static void _cbDialog(WM_MESSAGE * pMsg) { static GUI_MEMDEV_Handle hMemKnob; WM_HWIN hParent; WM_HWIN hWin; GUI_RECT Rect; BUTTON_Handle hButton; KNOB_Handle hKnob; IMAGE_Handle hImage; TEXT_Handle hText; int Id, NCode; U8 i, ImgCount; ImgCount = GUI_COUNTOF(_aBitmapItem); hWin = pMsg->hWin; switch (pMsg->MsgId) { case WM_INIT_DIALOG: // Create and fill memory devices hMemKnob = GUI_MEMDEV_CreateFixed32(0, 0, 140, 20); //_DrawKnob(hMemKnob); // Init KNOB hKnob = WM_GetDialogItem(hWin, GUI_ID_KNOB0); KNOB_SetDevice(hKnob, hMemKnob); KNOB_SetBkColor(hKnob, GUI_TRANSPARENT); KNOB_SetRange(hKnob, 0, 14); KNOB_SetOffset(hKnob, 14); KNOB_SetTickSize(hKnob, 170); KNOB_SetPeriod(hKnob, 50); KNOB_SetPos(hKnob, 14); // Initialization Buttons for (i = 0; i < 3; i++) { hButton = WM_GetDialogItem(hWin, ID_BUTTON_0 + i); BUTTON_SetBitmapEx(hButton, BUTTON_BI_UNPRESSED, _bntIco[i], 4, 4); } // Initialization Icons for (i = 0; i < ImgCount; i++) { hImage = WM_GetDialogItem(hWin, _aBitmapItem[i].imgId); IMAGE_SetBitmap(hImage, _aBitmapItem[i].pBitmap); } // Initialization text hText = WM_GetDialogItem(hWin, ID_TEXT_0); GUI_SetTextMode(GUI_TM_TRANS); TEXT_SetFont(hText, FONT_EXPLANATION); TEXT_SetDefaultTextColor(AMP_COLOR_BLUE); break; case WM_PAINT: //draw background GUI_DrawBitmap(&bmBackGround, 0, 0); GUI_DrawBitmap(&bmKnob, 163, 85); //draw LED _DrawScale(WM_GetDialogItem(hWin, GUI_ID_KNOB0), WM_GetDialogItem(hWin, ID_TEXT_0)); break; case WM_NOTIFY_PARENT: Id = WM_GetId(pMsg->hWinSrc); NCode = pMsg->Data.v; switch(Id) { case GUI_ID_KNOB0: switch(NCode) { case WM_NOTIFICATION_VALUE_CHANGED: hKnob = WM_GetDialogItem(hWin, Id); WM_GetWindowRectEx(hKnob, &Rect); Rect.x0 = 150; Rect.y0 = 50; Rect.x1 = 360; Rect.y1 = 272; hParent = WM_GetParent(hKnob); WM_InvalidateRect(hParent, &Rect); break; } break; case ID_BUTTON_0: switch(NCode) { case WM_NOTIFICATION_CLICKED: break; case WM_NOTIFICATION_RELEASED: break; } break; case ID_BUTTON_1: switch(NCode) { case WM_NOTIFICATION_CLICKED: break; case WM_NOTIFICATION_RELEASED: break; } break; case ID_BUTTON_2: switch(NCode) { case WM_NOTIFICATION_CLICKED: break; case WM_NOTIFICATION_RELEASED: break; } break; } case WM_NOTIFICATION_RELEASED: switch (Id) { case ID_BUTTON_0: hButton = WM_GetDialogItem(hWin, Id); break; case ID_BUTTON_1: hButton = WM_GetDialogItem(hWin, Id); break; case ID_BUTTON_2: hButton = WM_GetDialogItem(hWin, Id); break; } break; default: WM_DefaultProc(pMsg); break; }}static void myMainMenu(void){ GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);}void MainTask(void){ myMainMenu();}
Thank you.
