Addional compiler options for Clang
  • Addional compiler options for Clang
    i switched compiler from gcc to clang. Now we are getting a lot of warnings like :
    "passing 'uint8_t *' (aka 'unsigned char *') to parameter of type 'char *' converts between pointers to integer types with different sign"
    So i was trying to use "/J " compiler switch to handle chars as unsigned. But if i Add "/J" to addional compiler arguments, i always get a Error like:
    "error reading '/J'" :-(
    What can i do?
    Use -fno-signed-char instead of /J
    Johannes
  • Hi Johannes,
    I tried your solution. The compiler was not complaining about the option anymore. But we still get the warning.
    It seem's the compiler is ignoring the option... or i understand something wrong.
    Please see attached pictures
