EMWIN initialization failure
  • EMWIN initialization failure
    hello
    i am trying to use EMWIN on my EFM32TG210F32 (4k ram, 32k flash) however when i call the GUI_Init() i get a region `FLASH' overflowed error
    when i build.
    1) how can i solve this? can i "thin" the GUI_Init?
    meaning remove some functions from it?
    because i dont need alot of the functions, just need some basic text\animation
    my LCD is LS013B7DH03
    in the file GUIConf.c a memory area gets dedicated to emWin. Try to put the array used for this into another region, like external RAM.
    in GUIConf.c it might look like this:
    1. #include "GUI.h"
    2. #include "BSP_GUI.h"
    3. /*********************************************************************
    4. *
    5. * Defines
    6. *
    7. **********************************************************************
    8. */
    9. //
    10. // Define the available number of bytes available for the GUI
    11. //
    12. #define GUI_NUMBYTES 0x180000
    13. //
    14. // Place GUI RAM into a section in RAM
    15. //
    16. static U32 aMemory[GUI_NUMBYTES / 4] __attribute__ ((section (".GUI_RAM")));
    17. /*********************************************************************
    18. *
    19. * Static code
    20. *
    21. **********************************************************************
    22. */
    23. /*********************************************************************
    24. *
    25. * Public code
    26. *
    27. **********************************************************************
    28. */
    29. /*********************************************************************
    30. *
    31. * GUI_X_Config
    32. *
    33. * Purpose:
    34. * Called during the initialization process in order to set up the
    35. * available memory for the GUI.
    36. */
    37. void GUI_X_Config(void) {
    38. //
    39. // Assign memory to emWin
    40. //
    41. GUI_ALLOC_AssignMemory(aMemory, GUI_NUMBYTES);
    42. }
    With '__attribute__xxx' we place the array into a section called GUI_RAM. This section is declared in the linker file and lays in the external RAM.
    1) i have an external flash and not external ram, does it matter? are there any difference in the configuration between them?
    2)once i declare this region in the linker file, what else do i need to do in order for emwin to manage the LCD via its driver?
    please help
    The post was edited 2 times, last by roinovi ().
