Something weird is going on, probably with setup. I'm using a Nordic nRF51422-xxAC target running out of flash and I can use eclipse with the j-link gdb server for everything but breakpoints. Setting the initial breakpoint at main works (it's listed as type temporary), clicking on any other line of code show a breakpoint (of type regular)...doesn't work. I can click multiple lines and I keep getting breakpoints even though I only have 2 in hardware. Changing the break point type doesn't do anything. Setting the initial breakpoint on download to anything other than main doesn't work? Does anyone have any ideas?
Running
Eclipse Luna SR1a (4.4.1)
J-link 4.96m (i also exhibits this issue)
Gnu ARM c/c++ j-link debugging ver 3.1.1.201412191510
updated:Eclipse Luna SR2 (4.4.2) and Gnu ARM c/c++ j-link debugging ver 3.1.2.201502281154 doesn't fix the issue
Running
The post was edited 3 times, last by jdattolo ().
