I am simulating my application using keypad hardkeys.
I have a window dialog that I would like to send a SHIFT-TAB key to select a widget focus.
It works perfectly fine using the GUI_KEY_TAB code, but I need to go in the opposite direction using a SHIFT_TAB code. The manual does not mention a define for SHIFT_TAB.
EMWIN works perfectly fine from windows keyboard when simulating, but when I try and send a key code for SHIFT_TAB using GUI_SendKeyMsg() nothing happens.
The code that I am using for SHIFT_TAB is code 15 (0xf). The documentation says any code between 0x20 and 0xff is accepted.
Am I using the incorrect keyboard code fro SHIFT_TAB?
SM.
SM.
The post was edited 2 times, last by ScaleMan ().
