Hi Adrain,
Please can you assist me with the FRAMEWIN_GetUserData & FRAMEWIN_SetUserData fucntions.
I am using emWin in a full multitasking configuration i.e. Lowest priority task calls the emWin update functions, and another higher priority task manages the user interface.
I have created a non-blocking dialog that contains a Framewin widget from within the user interface task (with extra user data defined for the Framewin widget in the resource table)
I am calling FRAMEWIN_SetUserData from the call back function on a key press event, and signalling an OS event to the user interface task which is waiting for this event. When this event is processed I then call the FRAMEWIN_GetUserData function, this always works correctly on the first call, but when I repeat the process again, I am not getting the expected data that was set in the callback function of the diaglog window.
I am using the returned value of GUI_CreateDialogBox as the object handle in the get function. And the pMsg->hWin as the object handle for the set function in the dialog callback
