Hi
Does Jlink software version 4.58a support sabre lite platform [using DDRAM]. I have tried to connect but following error message is generated
*** Error Message ***
arm-none-eabi-sprite: Opening device(s):
arm-none-eabi-sprite: hostname=(null), port=0, path=58006903
arm-none-eabi-sprite: options:
arm-none-eabi-sprite: settings-file=D:\install\sabre_lite.jlink
arm-none-eabi-sprite: semihosting=off
arm-none-eabi-sprite: Semihosting is disabled.
arm-none-eabi-sprite: Trying to load DLL 'arm-none-eabi-jlinkarm.dll'
arm-none-eabi-sprite: J-Link ARM DLL Version: 4.58a
arm-none-eabi-sprite: Doing I/O to stdin/stdout
arm-none-eabi-sprite: J-Link: TotalIRLen = 13, IRPrint = 0x0101
arm-none-eabi-sprite: J-Link: ARM AP[0]: 0x44770001, AHB-AP
arm-none-eabi-sprite: J-Link: ARM AP[1]: 0x24770002, APB-AP
arm-none-eabi-sprite: J-Link: ARM AP[2]: 0x14760010, JTAG-AP
arm-none-eabi-sprite: J-Link: Found Cortex-A9 r2p10
arm-none-eabi-sprite: J-Link: 6 code breakpoints, 4 data breakpoints
arm-none-eabi-sprite: J-Link: Data endian: little
arm-none-eabi-sprite: J-Link: Main ID register: 0x412FC09A
arm-none-eabi-sprite: J-Link: Cache Type register: 0x83338003
arm-none-eabi-sprite: J-Link: System control register:
arm-none-eabi-sprite: J-Link: Instruction endian: little
arm-none-eabi-sprite: J-Link: Level-1 instruction cache disabled
arm-none-eabi-sprite: J-Link: Level-1 data cache disabled
arm-none-eabi-sprite: J-Link: MMU disabled
arm-none-eabi-sprite: J-Link: Branch prediction not supported
arm-none-eabi-sprite: Adding J-Link flash algorithms
arm-none-eabi-sprite: Adding CFI flash algorithm
arm-none-eabi-sprite: Adding AT91SAM7Sxxx flash algorithm
arm-none-eabi-sprite: Adding EFM32G flash algorithm
arm-none-eabi-sprite: Adding FM3 flash algorithm
arm-none-eabi-sprite: Adding Kinetis flash algorithm
arm-none-eabi-sprite: Adding LPC21xx flash algorithm
arm-none-eabi-sprite: Adding SPIFI flash algorithm
arm-none-eabi-sprite: Adding STM32F10xxx flash algorithm
arm-none-eabi-sprite: Adding STR91xFA flash algorithm
arm-none-eabi-sprite: Adding Stellaris flash algorithm
arm-none-eabi-sprite: J-Link error: Bad JTAG communication: Write to IR: Expected 0x1, got 0x0 (TAP Command : 10) @ Off 0x5.
arm-none-eabi-sprite: error: Cannot reset hardware
arm-none-eabi-sprite: Got packet: 'qSupported:multiprocess+;qRelocInsn+'
arm-none-eabi-sprite: Sent response: 'E.fatal.Cannot reset hardware'
arm-none-eabi-sprite: Closing J-Link connection
Also sabre_lite.jlink file contents are here
[BREAKPOINTS]
ShowInfoWin = 1
EnableFlashBP = 2
BPDuringExecution = 0
[CFI]
CFISize = 0x00
CFIAddr = 0x00
[CPU]
OverrideMemMap = 0
AllowSimulation = 1
ScriptFile=""
[FLASH]
MinNumBytesFlashDL = 0
SkipProgOnCRCMatch = 1
VerifyDownload = 1
AllowCaching = 1
EnableFlashDL = 2
Override = 1
Device="MCIMX6Q6"
[GENERAL]
WorkRAMSize = 0x00
WorkRAMAddr = 0x00
[SWO]
SWOLogFile=""
[MEM]
RdOverrideOrMask = 0x00
RdOverrideAndMask = 0xFFFFFFFF
RdOverrideAddr = 0xFFFFFFFF
WrOverrideOrMask = 0x00
WrOverrideAndMask = 0xFFFFFFFF
WrOverrideAddr = 0xFFFFFFFF
[BREAKPOINTS]
ShowInfoWin = 1
EnableFlashBP = 2
[CFI]
CFISize = 0x00
CFIAddr = 0x00
[CPU]
OverrideMemMap = 0
AllowSimulation = 1
ScriptFile=""
[FLASH]
VerifyDownload = 1
AllowCaching = 1
EnableFlashDL = 2
Override = 1
Device="MCIMX6Q6"
[GENERAL]
WorkRAMSize = 0x00
WorkRAMAddr = 0x00
[SWO]
SWOLogFile=""
[MEM]
The post was edited 1 time, last by hafizqasim ().
