I tried to debug remotely using J-Link Pro with GDB server and found that I cannot use any other utility (j-link commander, j-link swo viewer, etc.) simultaneously ! I tried both via emulator ethernet interface and via remote server.
Error message: "Max. Number of connections exceeded".
Quote from
Quote from
You missed very important detail !Supports concurrent access to CPU by multiple applications
J-Link allows multiple applications to access a CPU at the same time. This has numerous applications. J-Link commander can be used in parallel to a debugger, a tool to communicate via DCC can be used in parallel to a debugger or a visualisation tool such as Micrium's u/C-Probe or SEGGER's kernel viewer embOSView. This feature is currently not available for Cortex A and R cores.
