OS_GetMailCond1 question
  • OS_GetMailCond1 question
    I'm using OS_GetMailCond1 as such
    if (OS_GetMailCond1(&mb,&key))
    process(key);
    But it seems that this is no good since the data is left in the mail box buffer.
    I experimented by using OS_PutMailCond1(&mb,&c) only once, but the process key would run forever.
    Does OS_GetMailCond1 not clear the buffer automatically? Am I over simplifying this?
    I went to
    if(OS_GetMessageCnt(&mb))
    process(key);
    And that seems to work. But, I don't understand the operation of OS_GetMailCond1(&mb,&key) returning success if the result of OS_GetMessageCnt(&mb) is zero.
    Am I making a bad assumption or is something wrong?
  • I guess you made a simple mistake.
    The return values of OS_GetMailCond1() are:
    Return value
    0: Success; message retrieved.
    1: Message could not be retrieved (mailbox is empty); destination remains
    unchanged.
    Therefore (OS_GetMailCond1(&mb,&key)) is true when the mailbox is empty.
    This should be the right code:
    if (OS_GetMailCond1(&mb,&key) == 0) {
    process(key);
