Hy,
I've a problem connecting to JLink with Ubuntu 12.04. I installed everything as mentioned in the readme, but when I try to run the start script I get the following errorMessage:
./JLinkExe: error while loading shared libraries: libusb-0.1.so.4: cannot open shared object file: No such file or directory
I installed libusb.
locate libusb says the following:
/lib/x86_64-linux-gnu/libusb-0.1.so.4
/lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4
/lib/x86_64-linux-gnu/libusb-1.0.so.0
/lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
/usr/lib/libusbmuxd.so.1
/usr/lib/libusbmuxd.so.1.0.7
/usr/lib/x86_64-linux-gnu/libusb-1.0.so.0
/usr/share/doc/libusb-0.1-4
/usr/share/doc/libusb-1.0-0
/usr/share/doc/libusbmuxd1
/usr/share/doc/libusb-0.1-4/README.Debian
/usr/share/doc/libusb-0.1-4/changelog.Debian.gz
/usr/share/doc/libusb-0.1-4/copyright
/usr/share/doc/libusb-1.0-0/README
/usr/share/doc/libusb-1.0-0/changelog.Debian.gz
/usr/share/doc/libusb-1.0-0/copyright
/usr/share/doc/libusbmuxd1/changelog.Debian.gz
/usr/share/doc/libusbmuxd1/copyright
/var/lib/dpkg/info/libusb-0.1-4:amd64.list
/var/lib/dpkg/info/libusb-0.1-4:amd64.md5sums
/var/lib/dpkg/info/libusb-0.1-4:amd64.postinst
/var/lib/dpkg/info/libusb-0.1-4:amd64.postrm
/var/lib/dpkg/info/libusb-0.1-4:amd64.shlibs
/var/lib/dpkg/info/libusb-0.1-4:amd64.symbols
/var/lib/dpkg/info/libusb-1.0-0:amd64.list
/var/lib/dpkg/info/libusb-1.0-0:amd64.md5sums
/var/lib/dpkg/info/libusb-1.0-0:amd64.postinst
/var/lib/dpkg/info/libusb-1.0-0:amd64.postrm
/var/lib/dpkg/info/libusb-1.0-0:amd64.shlibs
/var/lib/dpkg/info/libusbmuxd1.list
/var/lib/dpkg/info/libusbmuxd1.md5sums
/var/lib/dpkg/info/libusbmuxd1.postinst
/var/lib/dpkg/info/libusbmuxd1.postrm
/var/lib/dpkg/info/libusbmuxd1.shlibs
/var/lib/dpkg/info/libusbmuxd1.symbols
and lsusb also finds the J-Link
Bus 005 Device 008: ID 1366:0101 SEGGER J-Link ARM
can somebody help me fixing this issue?
I installed libusb.
