I have a menu with several windows which is created using windows manager. Also I've configured memdev and double buffering. When I switch between menu. When new menu or submenu opening, I see how it is drawing window line by line, it is performed too fast (0.5 sec for 800x480 whole display) but it makes representing bad. Its like a horizontal line goes through the display from top to the bottom and draws a frame. There are no same problem if Memory device is switched off, but there is flickering problem in this case. Have you got any ideas why does it occurs and how to solve this problem?
Anton
Anton
