[SOLVED] Systemview freeRTOS start recording
  • [SOLVED] Systemview freeRTOS start recording
    I have configured my application with freertos (without patch) to use Systemview. I start recording, target is reset after while I stop recording. But there is nothing recorded. I don't get any information about tasks. In my main I call "SEGGER_SYSVIEW_Conf()" Can you help? Attached is what I get.
    rum
  • Brainfuck Source Code
    1. /*File : SEGGER_SYSVIEW_FreeRTOS.h Purpose : Interface between FreeRTOS and SystemView.
    2. Include this file at the end of FreeRTOSConfig.h
    3. --------- END-OF-HEADER ---------------------------------------------*/
    maybe it helps to include SEGGER_SYSVIEW_FreeRTOS.h at the end of FreeRTOSConfig.h
  • Of course file is included. When Systemview attaches, application will crash. I have increased stack for all tasks, now there is plenty of space >200byte as suggested. I have stack overflow monitor in place and I think it is not the stack. I cannot detect reason why application resets. There is no useful info from callstack. I find application sitting at reset vector. I have also applied patch to freeRTOS. What else can I check?
    Please update to the latest V2.30 sources,
    which fix a bug in the FreeRTOS SystemView interface and could cause an assertion.
    Johannes
    Thank you, new version 2.3 is much better and is running now on my XMC device. Great!
    I have another problem. Recording halts after about 5sec with message "Invalid packet received, Recording stopped". Attached is screenshot with last actions recorded. Do you have any suggestions? I am running SWO interface at maximum speed 50MHz and I am using ULTRA+ probe.
    rum
    Could you provide a SystemView recording which shows the invalid packet?
    Johannes
  • Problem has been solved via mail. For completeness:
    The invalid packets where caused by a locking problem.
    In the SEGGER_SYSVIEW_LOCK() / SEGGER_RTT_LOCK() all interrupts which could create SystemView events should be disabled (masked).
    For FreeRTOS and Cortex-M3/4 use either following macro or redirect lock and unlock to the FreeRTOS functions.
    1. #define SEGGER_RTT_LOCK() { \
    2. unsigned int LockState; \
    3. __asm volatile ("mrs %0, basepri \n\t" \
    4. "mov r1, %1 \n\t" \
    5. "msr basepri, r1 \n\t" \
    6. : "=r" (LockState) \
    7. : "i" ( configMAX_SYSCALL_INTERRUPT_PRIORITY) \
    8. : "r1" \
    9. );
    - Johannes
  • for the lock function,
    what is the complete macro for SEGGER_RTT_LOCK() and SEGGER_RTT_UNLOCK()?
    I got the errors in the attachment.
    The post was edited 1 time, last by shenj ().
  • You missed the backspace in the first line:
    Johannes
